- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Implementing a rewriting search tactic
- Date: Tue, 14 Aug 2007 03:37:02 +0100
- Organization: School of Informatics, The University of Edinburgh
Hi,
I'm wanting to develop a Coq tactic that, given a database of rewrite rules,
will perform a search of all possible ways the current goal can be rewritten.
I'm wanting to experiment with the use of heuristics to guide the search.
Specifically, if I had the rewrite rules "a=b", "b=c" and the goal "a+a=b",
the first stage in the search would be to use each rewrite only once on the
goal in all possible ways to produce the new goals "b+a=b", "a+b=b"
and "a+a=c". I would then repeat this for the new goals, using heuristics to
guide which goals to explore.
I would rather use Ltac for this if I could, but it doesn't appear to give
enough control in terms of using a database of rules, caching explored nodes
etc. My only other option is to use OCaml but I'm having a lot of trouble
getting going because I can't find any good documentation.
I looked at modifying "auto" but this doesn't appear to use rewrite rules in
the sense of Coq's "rewrite" tactic which I want. I had a look at
the "autorewrite" tactic; this looks more like what I need but it doesn't
appear to exhaustively apply rewrites and only explores one path. Are there
other tactics that work more like my description?
What OCaml (or Coq) commands can I make use of to generate the next set of
goals to search? Coq's "rewrite X" tactic seems to rewrite with X as many
times as it can when I need to find all the ways X can be used only once. Is
there a simple way to generate all these possibilities?
Also, I noticed an OCaml file involving discrimination nets, which auto
appears to use. As I would like this tactic to be scalable, is there some way
I can make use of this?
Any pointers would be greatly appreciated.
Regards,
Sean
- [Coq-Club] Implementing a rewriting search tactic, Sean Wilson
