- To: Pierre Courtieu <pierre.courtieu AT cnam.fr>
- Cc: Ethan Aubin <ethan.aubin AT gmail.com>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] rose tree equality
- Date: Tue, 18 Sep 2007 09:48:27 +0200
Pierre Courtieu wrote:
Le Mon, 17 Sep 2007 22:50:56 -0400, "Ethan Aubin"Rose trees are described in the Coq'Art book, under a different name (they are called ltree).
a écrit:
Hi, I'm stuck trying to prove decidable equality for rose trees
Inductive rose := Rose : nat -> list rose -> rose.
Lemma rose_eq_dec : forall (x y:rose), {x=y}+{x<>y}.
decide equality seems to need rose_eq_dec in the context to pass to
list_eq_dec. induction on x doesn't add an induction hypothesis (because the
subtrees are contained in the list?). Whats the strategy to solve a problem
like this? Many thanks- Ethan
You need to build and proof the right induction principle first, as the
default one built by coq is not powerfull enough.
The technique to build the right induction principle is also described: Chapter 14, Section 3.3.
Even if you don't have a paper copy of the book, the example appears on the web-site for
the book:
http://www.labri.fr/perso/casteran/CoqArt/induc-fond/SRC/chap14.v
Look for ltree and ltree_ind2.
You will need to transpose ltree_ind2 for your needs. For instance, you can try to define
directly your equality decision function using the same structure (this may be a little difficult).
If you prefer, you can define ltree_rec2 to work with a P and Q in sort Type or Set, and then
define your own function in proof mode (this should be easier).
Now, Pierre's proposal to use a pair of mutually inductive types is viable alternative.
Yves
- [Coq-Club] rose tree equality, Ethan Aubin
- Re: [Coq-Club] rose tree equality,
Pierre Courtieu
- Re: [Coq-Club] rose tree equality, Yves Bertot
- Re: [Coq-Club] rose tree equality, roconnor
Pierre Courtieu
