- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Hints in the FSets library
- Date: Wed, 17 Oct 2007 09:50:15 -0400
Hi,
I do not understand a couple of the design choices made in the FSets library. Both my questions have to do with the Hints declared in FSetInterface.S.
[1] What is the motivation behind adding so many properties to the *core* automation database? For example, properties such as inter_1 and inter_2 seem like they should to interact rather poorly with eauto.
[2] Why are the Hints hidden from the documentation generated by coqdoc? The behavior of (e)auto on some finite-set goals confused me until I realized that there were Hints being declared.
Thank you in advance for any insights and clarification.
Cheers,
Brian
- [Coq-Club] Hints in the FSets library, Brian Aydemir
- Re: [Coq-Club] Hints in the FSets library,
Pierre Letouzey
Aaron Bohannon
- Re: [Coq-Club] Hints in the FSets library, Pierre Letouzey
Aaron Bohannon
Pierre Letouzey
