- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Aaron Bohannon <bohannon AT cis.upenn.edu>
- Cc: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Hints in the FSets library
- Date: Tue, 30 Oct 2007 17:01:10 +0100
On Mon, Oct 22, 2007 at 10:03:34PM -0400, Aaron Bohannon wrote:
> On 10/19/07, Pierre Letouzey
> wrote:
> > One last comment about Fsets and automation. Since this discussion:
> > http://pauillac.inria.fr/pipermail/coq-club/2007/002949.html
> > I plan someday to write a specialize tactic aiming at FSet proofs.
> > For instance, doing in Ltac something more clever that eauto + the
> > aforementioned hints should not be difficult. Now, writing a _fast_
> > and _complete_ tactic solving the class of problems mentionned by
> > Aaron Bohannon can be more challenging.
> In fact, I have been working on implementing an idea of the form I
> proposed earlier. I realized that by narrowing the scope somewhat, it
> would be feasible to write such a tactic in the Ltac language.
> However, the narrower scope is still large enough to be extremely
> useful. By the same token the scope is large enough to make it very
> difficult to write a comprehensive set of unit tests, so I have been
> waiting to see what bugs were found as my friends at Penn tried use it
> in their own projects. I have worked out enough bugs that I think it
> might be at a beta-level of quality, so I am attaching the code here
> for others to look at -- and perhaps even consider for inclusion in
> the standard library at some point in the future.
> There are two files: DecidableProp.v, which extends Decidable.v from
> the standard library, and FSetDecide.v, a very well-documented file
> which implements a tactic [decideFSet] that is a decision procedure
> for a certain class of goals involving finite sets. The precise class
> of goals is clearly stated within the comments of the file. I'd love
> to hear any comments anyone has about this. In particular, I'd like
> to know if people find bugs or stumble across reasonable-sized cases
> where it runs too slowly to be practical.
> -Aaron
Hi Aaron,
I've just tried your tactic and it looks great. For instance, all
lemmas in section BasicProperties of FSetProperties are solved
automatically by it, apart from
Lemma double_inclusion : s1[=]s2 <-> s1[<=]s2 /\ s2[<=]s1.
which is indeed not in the scope you describe in FSetDecide (logical
combinators involving [=] and [<=], not just In and E.eq). And anyway
a simple "intuition decideFSet" does the job here. The only other
manual help given to decideFSet concerns lemmas involving the
predicate Add: since decideFSet knows nothing about Add, I rewrite
first every (Add x s s') into s'[=]add x s.
By the way, I've encountered one situation that has puzzled me:
Lemma Solvable : forall a x s,
E.eq x a \/ In a s <-> In a (add x s).
The previous lemma is solved ok by decideFSet, but if there is an
artificial s' in the middle of the iff, it stops working:
Lemma Not_Solvable : forall a x s s',
(In a s' <-> E.eq x a \/ In a s) ->
(In a s' <-> In a (add x s)).
I haven't investigated further, I'll have a closer look later.
Now comes the key question: have you anything against an inclusion of
FSetDecide.v in the Standard Library of Coq ? Of course, you would
retain proper credit for this file (and all our thanks). Such files of
Coq are then released under the LGPL 2.1 license. In a first time, the
only modifications I would do is ... changing the name of the tactic,
since the rest of the system uses lowercase tactic names. What about
fsetdec ? I may also try to allow using FSetDecide on both FSets and
FSetWeak (via some subtyping, work in progress).
Best regards,
Pierre Letouzey
- [Coq-Club] Hints in the FSets library, Brian Aydemir
- Re: [Coq-Club] Hints in the FSets library,
Pierre Letouzey
Aaron Bohannon
- Re: [Coq-Club] Hints in the FSets library, Pierre Letouzey
Aaron Bohannon
Pierre Letouzey
