- From: Pierre Cast�ran <pierre.casteran AT labri.fr>
- To: Wan Hai <wan.whyhigh AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0
- Date: Wed, 31 Oct 2007 14:39:26 +0100
Hi,
test1 is proved using the inversion tactic, which uses the fact that
the only way to prove n <= 0 is given by le's first constructor.
Lemma test1 : forall n:nat, n<=0 -> n=0.
intros n H; inversion H.
trivial.
Qed.
For test2, have a look at Coq's standard library : module Arith / Minus
section "Relation" with Plus.
By the way, your statement of test2 seems to be erroneous: assume
"m <= n" isnstead of "n <= m".
Pierre
Quoting Wan Hai
<wan.whyhigh AT gmail.com>:
Deal all,
Now I'm using Coq to prove something list as follows:
1) Lemma test1 : forall n:nat, n<=0 -> n=0
1) Lemma test2 : forall n m:nat, n<=m -> n-m+m=n
these are right of course, but I don't know how to prove. I used the
omega tactic. This tactic did solve these problems. But when I used
Print test1 or Print test2 to see what happens, I really find the
proof steps are difficult to follow.
Could any one tell me some easy way to do this?
Thanks a lot!
Hai Wan
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Castéran
- [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Wan Hai
- Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Pierre Castéran
- Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Yevgeniy Makarov
