- To: "Coq Club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0
- Date: Wed, 31 Oct 2007 14:57:36 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=Ugvvm06XYBsJhL61fgxzvEmLexZBooSKsJA/IaRBH2X/qK6bKaH/X62pVNT1NaHYOT3XTmsrr2h7uAXcgWHVs6m6sSrLlCAm87vFV3MWa3E3Pxscd9KNDPclKAV5BuIGZmz80/0fq+2yMjqdhy1UuCv9hiucYqoCkMmrqQwgo38=
Hello,
test1 could also be proved using the theorem le_n_O_eq from the
standard library (Coq.Arith.Le).
Lemma test1 : forall n : nat, n <= 0 -> n = 0.
Proof.
intros n H. symmetry. apply le_n_O_eq; assumption.
Qed.
You can find the theorem name using the command
SearchPattern (0 = _).
once you import Arith library. Finally, it can be proved using the
omega tactic, but first you need to introduce the universally
quantified variable:
Proof.
intro. omega.
Qed.
Omega can also solve the second goal. Otherwise, use the theorem
le_plus_minus.
Evgeny
- [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Wan Hai
- Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Pierre Castéran
- Re: [Coq-Club] help, how to prove this? forall n:nat, n<=0 -> n=0, Yevgeniy Makarov
