- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: frederic.blanqui AT loria.fr, coq-club AT pauillac.inria.fr, color AT loria.fr
- Subject: Re: [Coq-Club] "Concrete" multiset?
- Date: Wed, 07 Nov 2007 12:40:11 +0100
Edsko de Vries a e'crit :
Section test.
Variables (M1 M2: NatList.Multiset).
Variable P : NatList.Multiset -> Prop.
Hypothesis p : P (NatList.union M1 M2).
Lemma p' : P (NatList.union M2 M1).
At this point I'd like to do
rewrite NatListTheory.union_comm ; assumption.
to finish the proof, but that tells me
User error: Either the term NatList.union M2 M1 that must be rewritten
occurs in a covariant position or the goal is not made of morphism
applications only. You can replace only occurrences that are in a
contravariant position and such that the context obtained by
abstracting them is made of morphism applications only.
Hi,
If you could have proved p', after closing the section test, you would get
p' : forall M1 M2, forall P, P (Natlist.union M1 M2) -> P (Natlist.union M2 M1),
which is equivalent to Leibniz equality of the two unions.
In order to do your rewrite, Coq needs that the enclosing P is a morphism wrt
Meq, which is not in your hypotheses.
Pierre
and I have absolutely no idea what that means. Any pointers?
Thanks!
Edsko
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] "Concrete" multiset?, Edsko de Vries
- Re: [Coq-Club] "Concrete" multiset?,
frederic . blanqui
Edsko de Vries
- Re: [Coq-Club] "Concrete" multiset?, Pierre Casteran
Edsko de Vries
frederic . blanqui
- Re: [Coq-Club] "Concrete" multiset?, Edsko de Vries
frederic . blanqui
Edsko de Vries
- Re: [Coq-Club] "Concrete" multiset?, frederic . blanqui
Edsko de Vries
Pierre Letouzey
- Message not available
- Re: [Coq-Club] "Concrete" multiset?, Pierre Letouzey
frederic . blanqui
