coq-club - Re: [Coq-Club] proving the substitution lemma
chronological Thread
  • To: "Moez A. Abdel-Gawad" <moez AT cs.rice.edu>
  • Cc: coq-club AT pauillac.inria.fr, nominal-isabelle AT mailbroy.informatik.tu-muenchen.de
  • Subject: Re: [Coq-Club] proving the substitution lemma
  • Date: Thu, 8 Nov 2007 15:02:36 -0500
On Nov 8, 2007, at 1:22 PM, Moez A. Abdel-Gawad wrote:
In my quest to learn Coq, I started playing with a personal implementation of lambda calculus.
If you are seeking to implement lambda-calculus as is normally done "on paper," then it is worth noting that you have not defined capture- avoiding substitution. For example, the following holds:
Lemma subs_can_capture :
  subs "x" (Abs "y" (Var "x")) (Var "y") = (Abs "y" (Var "y")).
Proof. reflexivity. Qed.
I'm not sure if you intended this behavior or not.
It was also nice to know that there is an ongoing project that is trying to solve this deficiency (which is a deficiency that exists, it seems to me, in most semi-automated theorem provers in general, not only in Isabelle and Coq).
Representing syntax with binding (e.g., the lambda calculus) and working with such representations is a well-known problem that has received considerable attention over the past years. It takes some thought and care to be completely formal and correct about statements such as "by the Barendregt Variable Convention, we assume that ..." and actions such as causally renaming terms to alpha-equivalent ones. For example, if you want to be able to rename an arbitrary term to an alpha-equivalent one and treat the two terms as equal, then you have to show that any function you apply to that term respects alpha-equivalence.
--Brian
