- To: "Moez A. Abdel-Gawad" <moez AT cs.rice.edu>
- Cc: coq-club AT pauillac.inria.fr, cl-isabelle-users AT lists.cam.ac.uk, nominal-isabelle AT mailbroy.informatik.tu-muenchen.de
- Subject: [Coq-Club] [nominal-isabelle] proving the substitution lemma
- Date: Thu, 8 Nov 2007 21:52:16 +0100
Dear Moez,
Moez A. Abdel-Gawad writes:
> First, I would think thus that something simpler than the new nom-
> inal-isabelle constructs (nominal_datatype, nominal_induction,
> avoiding, fresh_fact, forget, etc) maybe more intuitive, and also
> more straight-forward to add (to Isabelle, or other semi-automated
> theorem provers).
I completely agree with your view that matters with formalising
the lambda-calculus *should* be simple, but I often found that
they aren't.
> Next, I also concluded that the substitution lemma, even though
> well-known to many PL researchers, may NOT be a very convincing
> example to cite (eg, on the webpage) for developing the new 'nom-
> inal-isabelle' package.
I am open for your suggestions! However it seems you have inadvertently
given a good reason that it *is* a good example.
My Coq-abilities are not very good, but reading
> Require Import String.
> Inductive LCterm: Set :=
> | Var : string -> LCterm
> | Abs: string -> LCterm -> LCterm
> | App: LCterm -> LCterm -> LCterm.
> Require Import Ensembles.
> Fixpoint FV(t: LCterm): Ensemble string :=
> match t with
> | Var x => Singleton string x
> | Abs x t1 => Subtract string (FV t1) x
> | App t1 t2 => Union string (FV t1) (FV t2)
> end.
> Fixpoint subs(x: string) (t: LCterm) (t': LCterm){struct t}: LCterm :=
> match t with
> | Var y => if string_dec y x then t' else t
> | Abs y t1 => if string_dec y x then t else Abs y (subs x t1 t')
> | App t1 t2 => App (subs x t1 t') (subs x t2 t')
> end.
you defined *possibly-capturing* substitution , namely
(Var y)[x:=t] = (if x=y then t else (Var y))
(Abs y t1)[x:=t] = (if x=y then (Abs y t1) else (Abs y (t1[x:=t])))
(App t1 t2)[x:=t] = App (t1[x:=t]) (t2[x:=t])
In the second clause you will capture any free occurrence of y
in t by moving the substitution under the binder.
If I am not mistaken and you indeed defined possibly-capturing
substitution and also used a concrete representation of lambda-terms,
then your substitution lemma
> Lemma subs_lemma: forall x y: string, forall M N L: LCterm,
> x <>y -> ~ In string (FV L) x ->
> subs y (subs x M N) L = subs x (subs y M L) (subs y N L).
is not true. James Cheney just did a few calculations and found
the following counter-example
(Abs y (Var x))[x:=y][y:=z] <> (Abs y (Var x))[y:=z][x:=y[y:=z]]
Disregarding this counter-example, the point of the substitution
lemma is, however, to show this property for capture-avoiding
substitution. The trouble then starts: your substitution
operation needs a precondition (I am not sure whether one can
state such a precondition of in Coq) or one needs to do a renaming
(I am also not sure how to define this cleanly in Coq). Also, if
you insist on a concrete representation, you need to state it not
as an equality, but an *alpha-equivalence*. You would also need
to define this in Coq.
Best wishes,
Christian
- [Coq-Club] proving the substitution lemma, Moez A. Abdel-Gawad
- [Coq-Club] Re: proving the substitution lemma, Brian Aydemir
- Re: [Coq-Club] proving the substitution lemma, Marco Maggesi
- <Possible follow-ups>
Moez A. Abdel-Gawad
- Re: [Coq-Club] proving the substitution lemma, Brian Aydemir
- [Coq-Club] [nominal-isabelle] proving the substitution lemma, Christian Urban
