- To: "Evgeny Makarov" <emakarov AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Induction
- Date: Sat, 10 Nov 2007 21:17:27 +0100 (CET)
- Importance: Normal
Hi Evgeny,
thanx for answer. It seems like good explanation of this "User error". But
anyway, "Hx is used in hypothesis v" seems like a bug (at least
explanation) because it is not self-explanatory.
Greetings,
Marko Malikoviæ
Evgeny Makarov reèe:
> Hi,
>> Coq < Hypothesis Hx : values x.
>> Coq < Goal x<=4.
>>> induction Hx.
>> User error: Hx is used in hypothesis v
> I believe the reason for the error is that the induction tactic erases
> the term which is its argument from the context. Note that when the
> theorem is "values x -> x <= 4" and you say "intro Hx; induction Hx", Hx
> is no longer in the context. If Hx is an axioms then it is not in the
> local context, so apparently this is OK as well. But when Hx is declared
> as a hypothesis, you cannot erase it from the context because your
> theorem is using it. The error message "Hx is used in hypothesis" is
> usually issued by the "clear" tactic. However, I admit that saying "in
> hypothesis v" is cryptic.
> You can say "elim Hx" or "case Hx" (but not "destruct Hx", which also
> tries to clear Hx).
> Evgeny
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Induction, Marko Malikoviæ
- [Coq-Club] Induction - Appendix, Marko Malikoviæ
- Re: [Coq-Club] Induction,
Evgeny Makarov
- Re: [Coq-Club] Induction, Marko Malikoviæ
