- From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] eauto and avoiding non-instantiated existential variables
- Date: Sun, 11 Nov 2007 02:10:22 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:user-agent:mime-version:cc:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=ZICOyBnVRm6vMhbTlPAODpSvrk1eMTTNiBIaSdhZpB8Ce2imNaPkYf0lXRuQNUfNBsgWRiuVAao7OSCy9L19h8aJq603yMLOeAih2yC5jH/l6ggUbpu7rQxIygYziRozJFLoPbwciHe7hJQCYuUmodJORHU9i3bJRXy5l0YHj6U=
Robin Green a écrit :
I am getting the error about non-instantiated existential variables[1]Hi,
after using eauto sometimes, and I have the following two
questions:
To begin with, even if the answer is not so much satisfactory, these errors should disapear in a forthcoming version of Coq (either in next release if I am quick, both at finishing my implementations, and at developping my diplomatic skill in order to convince other Coq developpers that we should include it immediatly ; or in the one after (most likely the latter)). The reimplementation of the proof engine I'm working on has explicit goals for every metavariables, they can't disapear before the end of the proof (except using unsafe tactics like "exact_nocheck").
1. I'm not sure what this means. The FAQ says[1] "This means that eautoYou can't prove false things. If you have hidden metavariables, Qed will refuse to work. The only thing that can go into the context (i.e. that you can prove) are fully instantiated terms whose validity is independant from the correctness of the tactics (a proof term is fully rechecked when Qed occurs, that's why it takes time).
or eapply didn't instantiate an existential variable which eventually
got erased by some computation." The fact that it's erased, intuitively
suggests to me (although I could be completely wrong about this!) that
it's a bit like a term in a non-strict language which can provably
never be used, so can be set to "undefined". Would allowing
uninstantiated existentials in proofs mean that false conclusions could
be proven? (I presume so, otherwise why would it be disallowed?) If so,
can someone give a simple example of a proof script with an
uninstantiated existential, which constitutes a bogus "proof" of a
false statement?
Here is an example how it can happen :
Definition P (x:nat) := True.
Goal True.
refine ((fun x:P _ => _) _).
trivial.
exact I.
Then you can't go Qed. (the uninstantiated metavariable is the first underscore. Which is not needed to compute the proof since "P _" is always equal to nat).
2. Is there a technique to get eauto to avoid possible proofs whichI'm not qualified to answer to this part. But I don't think there is anything general in that direction. There is a command Instantiate (which is undocumented due to a rather poor syntax) which is intented to solve this kind of problems (finishing a proof which has uninstantiated metavariables). Unfortunately, I can't seem to remember its syntax. If someone does, it might possibly be useful as a temporary fix for your proofs.
leave existential variables instantiated? Right now, I am just reducing
the proof search depth, which works for these particular cases, but is a
total hack. Maybe there are certain lemmas which I should avoid adding
as hints?
Arnaud Spiwack
- [Coq-Club] eauto and avoiding non-instantiated existential variables, Robin Green
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Brian Aydemir
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Vasileios Koutavas
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Arnaud Spiwack
