- To: gbush <gbush AT mysck.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Accessibility Predicate in Simple Parser
- Date: Wed, 21 Nov 2007 11:45:28 +0100
gbush wrote:
Hello,Your problem is that you want to define a nested recursive function using a ad-hoc predicate.
I've been experimenting with a proof of a simple parser that I want to
extract into a nice program. I can complete the proof using well-founded
induction on the length of the string being parsed, but the proof extracts
to something like...
let rec parse x =
func x (fun y _ -> parse y).
... which is not very satisfying from my perspective.
The only reference to work where this is done that I know of is the work of Bove and Capretta,
and they argue that this problem can be solved using simultaneous induction-recursion, whereby
you define simultaneously an inductive predicate and a recursive function. This was described
by Peter Dybjer in 1991 and I believe (although I am not sure) that it is provided in Alfa.
So I believe you have to revert to a well-founded definition. But life is not so bleak, since you can
configure the Extraction facility so that you recognize you parsing function. This is what I obtained:
let rec parse = function
| Nil -> None
| Cons (x0, xs) ->
(match x0 with
| AtomToken -> Some (Pair (Atom, xs))
| ImpToken ->
(match parse xs with
| Some p ->
let Pair (p0, s) = p in
(match parse s with
| Some p1 ->
let Pair (q, s0) = p1 in
Some (Pair ((Imp (p0, q)), s0))
| None -> None)
| None -> None))
The Coq development is given below (I did not perform the obvious proofs). I used Fix
instead of well_founded_induction because Fix comes with a side theorem named Fix_eq, which will
be handy later if you want to reason about what your parse function does (for now, its only specification
is its code, and if it was defined using well_founded_induction, it would be difficult to prove that it
satisfies the natural fixpoint equation). My opinion is that we should stop using well_founded_induction
(or rename Fix into well_founded_induction), because they have the same type but Fix has the nice
companion theorem and Fix should be inlined by default (like well_founded_induction).
<<<<< Begin Coq code.
Require Import List Wf_nat.
Inductive Token : Set := AtomToken | ImpToken.
Inductive Term : Set := Atom | Imp(t1 t2:Term).
Definition t' (s l:list Token) := length l <= length s.
Definition t (s:list Token) :=
option(Term * {l:list Token | length l <= length s}).
Lemma th : forall s (x:Token) xs, x::xs=s -> length xs <= length s.
Admitted.
Lemma th1 : forall s (x:Token) xs, x::xs=s -> length xs < length s.
Admitted.
Lemma th2 : forall s (x:Token) xs, x::xs=s -> forall s':list Token,
length s' <= length xs -> length s' < length s.
Admitted.
Lemma th3 : forall s (x:Token) xs, x::xs=s -> forall s':list Token,
length s' <= length xs -> forall s'':list Token, length s'' <= length s' ->
length s'' <= length s.
Admitted.
Definition parse_F (s:list Token)
(parse : forall l: list Token, length l < length s-> t l) : t s :=
match s as x
return x = s -> t s with
nil => fun _ => None
| x::xs => fun hxs : x :: xs = s =>
match x with
AtomToken => Some (Atom, exist (t' s) xs (th s x xs hxs))
| ImpToken => match parse xs (th1 s x xs hxs) with
| None => None
| Some (P,exist s' hs') =>
match parse s' (th2 s x xs hxs s' hs') with
| None => None
| Some(Q, exist s'' hs'') =>
Some(Imp P Q, exist (t' s) s'' (th3 s x xs hxs s' hs' s'' hs''))
end
end
end
end (refl_equal s).
Definition parse := Fix
(well_founded_ltof _ (@length Token))
t parse_F.
Extraction Inline parse_F Fix.
Extraction "parse.ml" parse.
- [Coq-Club] Accessibility Predicate in Simple Parser, gbush
- Re: [Coq-Club] Accessibility Predicate in Simple Parser, Yves Bertot
