- To: coq-club AT pauillac.inria.fr
- Cc: Benjamin Pierce <bcpierce AT cis.upenn.edu>, Peter Morris <pwm AT Cs.Nott.AC.UK>, Benjamin Werner <Benjamin.Werner AT inria.fr>
- Subject: Re: [Coq-Club] Inductive definitions that go through lists
- Date: Wed, 21 Nov 2007 11:50:30 +0000
Hi,
some comments on the Benjamins' emails:
Indeed, every strictly positive operator on types F : Type -> Type gives rise to a modality:
P : A -> Type
[] F : F A -> Type
moreover, we have a dependent version of map
f : forall a:A, P a
dmap f : forall x:F A,[] P x
Using this, one can formulate a generic eliminator for the inductive type mu F:Type with the constructor
in : F(mu F) -> mu F:
P : mu F -> Type
m : forall x:F(mu F), [] P x -> P (in x)
elim P m : forall x:mu F, P x
and the computation rule
elim P m (in x) = dmap (elim P m) x
Benjamin P's type is isomorphic to the inductive type generated by
F X = nat + X * X + list X
which is strictly positive because X appears strictly positive in list X. This is the theory, how difficult (and how useful) it would be to implement it in Coq, I don't know.
Peter Morris investigated the [] modality (and its dual <>) in his recent PhD thesis on generic programming with dependent types (http:// www.cs.nott.ac.uk/~pwm/thesis.pdf).
Actually, in an extensional theory every functor gives rise to the []- modality, but only strictly positive ones (or containers) give rise to the dual <>, it seems. In any case, from a foundational point of view one may not want to accept non-strictly positive inductive types (like mu X.(X->Bool)->Bool) anyway.
Cheers,
Thorsten
On 21 Nov 2007, at 10:32, Benjamin Werner wrote:
Hello Benjamin,
The Coq implementation does not provide a good induction principle, but the type theory does not forbid it.
You first have to state what your induction principle has to look like, and thus what the induction
hypothesis for the (alist ty) looks like.
Here is one possibility. I just replaced alist by list for simplification:
Inductive ty : Set :=
| ty_base : nat -> ty
| ty_arrow : ty -> ty -> ty
| ty_rcd : (list ty) -> ty.
Fixpoint liftp (P:ty->Prop)(l:list ty) {struct l} : Prop := match l with
| cons t l => P t /\ liftp P l
| _ => True
end.
Lemma ty_myind : forall P : ty -> Prop,
(forall n : nat, P (ty_base n)) ->
(forall t : ty, P t -> forall t0 : ty, P t0 -> P (ty_arrow t t0)) ->
(forall a : list ty,liftp P a -> P (ty_rcd a)) ->
(forall t : ty, P t).
Proof.
fix 5.
intros P pb pa pl [n|t u|l].
apply pb.
apply pa; apply ty_myind; auto.
apply pl.
elim l.
simpl; trivial.
clear l; intros t l hl; split.
apply ty_myind; trivial.
assumption.
Qed.
Note that:
* When using the (not very documented) fix tactic, you have to be careful
not using your induction hypothesis too early in the proof. If not, you get
an unpleasant surprise when you do Qed.
(basically, fix gives you a too strong IH, it is your responsability to apply
it only to arguments which are structurally smaller).
* In the example above, you then have to prove that under the same hypotheses
you have (liftp P l) for any l: list ty
but this should be easy by (regular) induction over l and using ty_myind.
* The definitions of the type theory which make this correct are described in the ref man.
The fix tactic is in the tutorial on recursive types (Gimenez and Casteran).
Maybye there are smoother versions of the above. Also, my understanding is
that if this work is not done generically by Coq, it is a.o. because it is not so
trivial to state the good induction principle.
Hope this helps,
Benjamin
Le 21 nov. 07 04:20, Benjamin Pierce a crit :
This week, I wanted to show my programming languages class how to extend the simply typed lambda-calculus with records. So I wrote the obvious thing:
| ty_base : nat -> ty
| ty_rcd : (alist ty) -> ty.
This seemed happy for a while, until I discovered that the induction principle Coq had generated
ty_ind
(forall a : alist ty, P (ty_rcd a)) -> forall t : ty, P t
was completely useless! (The last case gives no IH for reasoning about records.)
I asked around a little at Penn and was told that this was a common issue and the usual way around it was to "lift" the nil and cons constructors of lists into my term syntax, like this:
| ty_base : nat -> ty
| ty_rcd_nil : ty
| ty_rcd_cons : nat -> ty -> ty -> ty.
This made me a little less happy because it slightly changes the language I'm defining, but I pushed ahead and succeeded in proving all the things I wanted to about the system.
Next, I'd like to show the class the "dual" extension: variants (i.e., disjoint sums with any number of labeled summands). But this time I'm even less happy. I'd like to write
Inductive tm : Set :=
| tm_var : nat -> tm
| tm_app : tm -> tm -> tm
| tm_abs : nat -> ty -> tm -> tm
| tm_inj : nat -> tm -> tm
| tm_case : tm -> list (nat * tm) -> tm.
where the last constructor represents an n-ary case construct whose concrete syntax might look like this:
case t0 of <l1=x1> => t1
| <ln=xn> => tn
This won't work for the same reason as before. And, while I can roughly see how to generalize the "case" constructor into a "nil" and a "cons" part as I did for records, this is really getting a bit awkward.
Is there a more direct way to do such things?
Thanks!
- Benjamin
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
- Re: [Coq-Club] Inductive definitions that go through lists, Robert Dockins
Benjamin Werner
- Re: [Coq-Club] Inductive definitions that go through lists, Thorsten Altenkirch
Stéphane Lescuyer
- Re: [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
Stéphane Lescuyer
Xavier Leroy
Xavier Leroy
- Re: [Coq-Club] Inductive definitions that go through lists, Francesco Zappa Nardelli
- Re: [Coq-Club] Inductive definitions that go through lists, Stefan Berghofer
Thorsten Altenkirch
Benjamin Werner
- Re: [Coq-Club] Inductive definitions that go through lists, frederic . blanqui
Benjamin Werner
Xavier Leroy
