coq-club - Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X
chronological Thread
  • From: Vincent Aravantinos <vincent.aravantinos AT yahoo.fr>
  • To: pierre.lescanne AT ens-lyon.fr
  • Cc: Edsko de Vries <devriese AT cs.tcd.ie>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X
  • Date: Mon, 26 Nov 2007 21:18:41 +0100
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=Received:X-YMail-OSG:In-Reply-To:References:Mime-Version:Content-Type:Message-Id:Cc:Content-Transfer-Encoding:From:Subject:Date:To:X-Mailer; b=TSCkKhRnCLBHwyK8MMLbxEZAc3l5KvsYVUpMGW33KvbZ/dygKu7OOFIXIcVjcEAdBlyyIvCy1kKqABIr8f5UOAp4hK6mA644Ciwyyfb6wGdjicaJYZT46Qq/de+jdsSd0CxnP3UK759TDJ/3tE5+4Ukm+IGj7ZtfCIDyCZKseyA= ;
Hi
Le 26 nov. 07 à 21:06, Pierre Lescanne a écrit :
Edsko de Vries a écrit :
On Mon, Nov 26, 2007 at 02:30:59PM +0100, Pierre Lescanne wrote:
I tried to update Coq on my Mac OS (intel) by downloading Coq_V8.1pl2_i386.pkg and installing it. Everything went fine till the end with no error message, but eventually Coq was not installed.
I had just to go back to my Darwin installation which has only the version 8.0pl3.
Just a wild guess here, but it often happens when I install stuff on Mac
OS X that it installs to a different location than a previous version of
the software, so that when I try to run it, it still runs the old
version because its location happens to be earlier in my PATH (or the
installation location of the new version may not be in the PATH at all).
May or may not be helpful :)
Edsko
Spotlight shows no "coqtop" or file like that, when the previous version has been uninstalled.
Don't know if Spotlight detects command-line tools... (actually it doesn't detect my coqtop whereas it is installed) Unless you have a plugin to make it do this ?
Anyway, maybe you'd better do a:
>sudo /usr/libexec/locate.updatedb
It will ask your password, wait until you get the command back. Then do:
>locate coqtop
You'll see if there are multiple copies...
HTH
V.
