- From: Pierre Lescanne <pierre.lescanne AT ens-lyon.fr>
- To: Vincent Aravantinos <vincent.aravantinos AT yahoo.fr>
- Cc: Edsko de Vries <devriese AT cs.tcd.ie>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X
- Date: Tue, 27 Nov 2007 11:23:43 +0100
- Organization: ENS de Lyon
OK, thanks for your trick, I found where the new version was hidden. I have now two versions: the old one as /opt/local/bin/coqtop and the new one as /usr/local/bin/coqtop
But (like Benjamin) I use proof general, but unlike him, I use xemacs and the new coq does not work with proof general, the well know problem of coding of xemacs.
I will try aquamacs
Pierre
Vincent Aravantinos a écrit :
Hi
Le 26 nov. 07 à 21:06, Pierre Lescanne a écrit :
Edsko de Vries a écrit :
On Mon, Nov 26, 2007 at 02:30:59PM +0100, Pierre Lescanne wrote:Spotlight shows no "coqtop" or file like that, when the previous version has been uninstalled.
I tried to update Coq on my Mac OS (intel) by downloading Coq_V8.1pl2_i386.pkg and installing it. Everything went fine till the end with no error message, but eventually Coq was not installed.
I had just to go back to my Darwin installation which has only the version 8.0pl3.
Just a wild guess here, but it often happens when I install stuff on Mac
OS X that it installs to a different location than a previous version of
the software, so that when I try to run it, it still runs the old
version because its location happens to be earlier in my PATH (or the
installation location of the new version may not be in the PATH at all).
May or may not be helpful :)
Edsko
Don't know if Spotlight detects command-line tools... (actually it doesn't detect my coqtop whereas it is installed) Unless you have a plugin to make it do this ?
Anyway, maybe you'd better do a:
>sudo /usr/libexec/locate.updatedb
It will ask your password, wait until you get the command back. Then do:
>locate coqtop
You'll see if there are multiple copies...
HTH
V.
- [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X, Pierre Lescanne
- Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X,
Edsko de Vries
Pierre Lescanne
Vincent Aravantinos
- Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X, Pierre Lescanne
Vincent Aravantinos
Pierre Lescanne
Benjamin Werner
Stefan Monnier
- Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X, Benjamin Werner
Stefan Monnier
- <Possible follow-ups>
- Re: [Coq-Club] installation of Coq_V8.1pl2_i386 on Mac OS X, Santiago Zanella
Edsko de Vries
