- From: Stephane Le Roux <stephane.le.roux AT ens-lyon.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Re: Strict Implicit
- Date: Thu, 06 Dec 2007 14:05:01 +0100
Hello,
Thank you for the answers. Also, sorry for not being clear enough; I have to
rephrase my question: Coq says that the first argument of g is implicit,
despite the command Set Strict Implicit (I expected that g would have no
implicit argument). Is this the intended behaviour? If that's so, is there a
simple example that shows the difference between Set Strict Implicit and Unset
Strict Implicit?
Cheers,
Stephane
Date: Wed, 05 Dec 2007 19:34:59 +0100
To:
Subject: [Coq-Club] Strict Implicit
Hello,
In the example below, Coq says that the first argument of a function is implicit
(despite the command Set Strict Implicit). Then, when trying to build a term
with the function, Coq says that the first argument cannot be inferred. Is this
the intended behaviour? Did I do something wrong?
Cheers,
Stephane
Coq < Set Implicit Arguments.
Coq < Set Strict Implicit.
Coq < Definition f (n : nat) := bool.
f is defined
Coq < Definition g(n: nat)(x:f n):= 0.
g is defined
Coq < Print g.
g = fun (n : nat) (_ : f n) => 0
: forall n : nat, f n -> nat
Argument n is implicit
Argument scopes are [nat_scope _]
Coq < Definition h:= g true.
Toplevel input, characters 15-16
Definition h:= g true.Error: Cannot infer an instance for the implicit parameter n of g
--__--__--
Message: 2
Date: Wed, 5 Dec 2007 20:33:44 +0100
To: Stephane Le Roux
Cc:
Subject: Re: [Coq-Club] Strict Implicit
<Jean-Francois.Monin AT imag.fr>
Hi,
Which value do you expect to be infered? Any expression e of type nat
could be passed as an argument.
Eg.:
Definition h:= @g 3 true.
Or:
Variable x : nat.
Definition h:= @g x true.
Hope this helps,
JF Monin
--__--__--
Message: 3
Date: Wed, 05 Dec 2007 20:44:36 +0100
<pierre.casteran AT labri.fr>
To: Jean-Francois Monin
Cc: Stephane Le Roux
<stephane.le.roux AT ens-lyon.fr>,
Hi,
You can also give an explicit type to true, and n is inferred:
Definition h := g (true: f 42).
Pierre
- [Coq-Club] Re: Strict Implicit, Stephane Le Roux
