- To: "Sean Wilson" <sean.wilson AT ed.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Intro in Ltac
- Date: Thu, 6 Dec 2007 23:27:50 +0100 (CET)
- Importance: Normal
Dear Sean, so you also combine intro with another tactic when using try.
But it can be little uncouthly if you have 20-30 subgoals, you don't know
if intro is possible and if after all intros you use different tactics in
different subgoals depending on other hypotheses in subgoals.
Greetings,
Marko
Sean Wilson reèe:
> On Thursday 06 December 2007 18:51:40 Marko Malikoviæ wrote:
>> Greetings,
>> can somebody give me a reason why first example work, but second not:
>> Ltac test :=
>> intro H1;
>> compute in H1;
>> assumption.
>> Goal 2+3=5 -> 5=5.
>> test.
>> Ltac test :=
>> try intro H1;
>> compute in H1;
>> assumption.
>> Goal 2+3=5 -> 5=5.
>> test.
>> I need to build Ltac but I don't know how many intros are possible to do
>> in particular subgoal. Is it some solution?
> This is a hack, but you can do something like this:
> (intros x y z H; compute in H ||
> intros x y H; compute in H ||
> intros x H; compute in H ||
> intros H; compute in H ||
> fail "Too many variables?")
> The first intros will fail if there aren't enough variables, so the second
> intros is attempted with one less variable and so on until hopefully one
> of
> the intros works. It will break if you have a subgoal with too many
> variables
> though. Make sure to put in a recognisable error message so you know to
> add
> more intros patterns later if this tactic fails.
> I'd like to know if there is a cleaner way to do this, but I find that I
> need
> to use hacks like this in Ltac quite often as it lacks certain fine
> control.
> This is another Ltac hack I use frequently when working with functions
> when I
> don't know the number of parameters needed:
> Ltac fun_name t :=
> match t with
> ?f ?a => f
> | ?f ?a ?b => f
> | ?f ?a ?b ?c => f
> | ?f ?a ?b ?c ?d => f
> | ?f ?a ?b ?c ?d ?e => f
> | _ => fail "fun_name: function has too many parameters!"
> end.
> Good luck,
> Sean
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Intro in Ltac, Marko Malikoviæ
- Re: [Coq-Club] Intro in Ltac,
Edsko de Vries
Marko Malikoviæ
- Re: [Coq-Club] Intro in Ltac - correction, Marko Malikoviæ
Edsko de Vries
- Re: [Coq-Club] Intro in Ltac, Marko Malikoviæ
Marko Malikoviæ
Sean Wilson
Edsko de Vries
