- To: devriese AT cs.tcd.ie
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Intro in Ltac
- Date: Fri, 7 Dec 2007 01:40:49 +0100 (CET)
- Importance: Normal
No, I don't need this. Imagine 30 subgoals and every subgoal like chain of
10, 15 or 20 implications: A -> B -> ... It is several groups of subgoals
with different number of possible intros (it depend on one of hypothesis
which have to be introduced also). Here is small example:
Parameter B C D E F Z : Prop.
Inductive arguments : Set := x | y | z.
Parameter P : arguments -> Prop.
Parameter u : arguments.
Parameter m : nat.
Axiom A1 : (m=1 -> C -> D -> E) -> Z.
Axiom A2 : (m=2 -> B -> C) -> Z.
Axiom A3 : (m=3 -> C -> D -> E -> F) -> Z.
Goal P u -> Z.
intro Hu;
induction u;
match goal with
| [ Hu : P x |- _ ] => apply A1
| [ Hu : P y |- _ ] => apply A2
| [ Hu : P z |- _ ] => apply A3
end;
And now I need to make intros. But, first I need to intro hypothesis of
value m. On value of m depend number of intros I have to do.
So, without Ltac definition it is:
intro Hm;
match goal with
| [ Hm : m=1 |- _ ] => intros H1 H2
| [ Hm : m=2 |- _ ] => intros H1
| [ Hm : m=3 |- _ ] => intros H1 H2 H3
end.
But I need recursion (!!!) and I need to make Ltac definition and put all
tactics into that definition. And here are problems:
1. I need to intro Hm without any compute or similary - I can not do it
2. I must to do pattern matching on goal and to intro rest of hypothesis.
Number of hypothesis depend on value of m. But I can not do it because of
problems we are talking about
Greetings,
Marko Malikoviæ
Edsko de Vries reèe:
> On Thu, Dec 06, 2007 at 11:11:18PM +0100, Marko Malikovi? wrote:
>> Intros work but even we know what name of introduced hypothesis will be
>> we
>> can not use it because system can not be sure it will be this name. And
>> it
>> is OK.
>> But pattern matching also don't work (because of the same reason I
>> think).
>> And what is the possibility of using intro in Ltac definitions if you
>> don't know is product exist? To combine it with some another tactics
>> like
>> you do?
>> If it is only possibility I will use it but it also seems unnaturally.
>> Furthermore, even this work:
>> Ltac test :=
>> try (intro H1;idtac).
>> Goal 2+3=5 -> 5=5.
>> test.
> I'm not sure what exactly you are trying to do, but if you need to
> 'search' for the hypothesis you need in the tactic, perhaps you could do
> something like
> Ltac test :=
> let H := fresh in
> intro H;
> (solve_using H || test).
> Where solve_using is some tactic that uses H (note: not tested, don't
> have access to Coq at the moment). This basically recursively tries to
> introduce a new hpothesis, tries to use that hypothesis, and if that
> fails, recursively tries the next.
> Edsko
- [Coq-Club] Intro in Ltac, Marko Malikoviæ
- Re: [Coq-Club] Intro in Ltac,
Edsko de Vries
Marko Malikoviæ
- Re: [Coq-Club] Intro in Ltac - correction, Marko Malikoviæ
Edsko de Vries
- Re: [Coq-Club] Intro in Ltac, Marko Malikoviæ
Marko Malikoviæ
Sean Wilson
Edsko de Vries
