- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10
- Date: Wed, 12 Dec 2007 23:04:14 +0100
I am trying to compile Coq 8.1pl2 with Ocaml 3.10. The Coq web page
indicates that this is possible. I have ocaml 3.10 and camlp5 installed
through Godi. The problem with Coq happens both in Godi and "manual"
compilation.
The ./configure script is happy (see below) but the compilation gets
stuck on:
OCAMLOPT4 tactics/hipattern.ml4
Error while loading "parsing/q_constr.cmo": file not found in path.
Preprocessor error
make[1]: *** [tactics/hipattern.cmx] Error 2
make[1]: Leaving directory `/home/andrej/compile/coq-8.1pl2'
There is a parsing/q_constr.ml4 file which does not seem to be compiled
for some reason. Is this a known issue, or is my computer just very
special? Any help is appreciated (and I apologize if this is the wrong
mailing list).
Andrej
P.S. Here is the result of ./configure:
$ ./configure --prefix /usr/local
You have Objective-Caml 3.10.0. Good!
You have native-code compilation. Good!
LablGtk2 found, native threads: native CoqIde will be available.
Should I compile the complete theory of real analysis [Y/N, default is Y] ?
y
Coq top directory : /home/andrej/compile/coq-8.1pl2
Architecture : i686
OS dependent libraries : -cclib -lunix
Objective-Caml/Camlp4 version : 3.10.0
Objective-Caml/Camlp4 binaries in : /usr/local/godi/bin
Objective-Caml library in : /usr/local/godi/lib/ocaml/std-lib
Camlp4 library in : +camlp5
Lablgtk2 library in : +lablgtk2
FSets theory : All
Reals theory : All
CoqIde : opt
Paths for true installation:
binaries will be copied in /usr/local/bin
library will be copied in /usr/local/lib/coq
man pages will be copied in /usr/local/man
emacs mode will be copied in /usr/local/share/emacs/site-lisp
/home/andrej/compile/coq-8.1pl2/theories
/home/andrej/compile/coq-8.1pl2/contrib
If anything in the above is wrong, please restart './configure'
*Warning* To compile the system for a new architecture
don't forget to do a 'make archclean' before './configure'.
- [Coq-Club] Coq 8.1pl2 and Ocaml 3.10, Andrej Bauer
- Re: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10,
Danko Iliḱ
- Re: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10, Andrej Bauer
Virgile Prevosto
- Re: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10, Jean-Marc Notin
Danko Iliḱ
