coq-club - Re: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10
chronological Thread
  • From: Virgile Prevosto <virgile.prevosto AT m4x.org>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Coq 8.1pl2 and Ocaml 3.10
  • Date: Thu, 13 Dec 2007 16:01:37 +0100
Hello Andrej,
Le mer 12 déc 2007 23:04:14 CET,
Andrej Bauer
<Andrej.Bauer AT fmf.uni-lj.si>
 a écrit :
> The ./configure script is happy (see below) but the compilation gets
> stuck on:
>  OCAMLOPT4 tactics/hipattern.ml4
>  Error while loading "parsing/q_constr.cmo": file not found in path.
>  Preprocessor error
>  make[1]: *** [tactics/hipattern.cmx] Error 2
>  make[1]: Leaving directory `/home/andrej/compile/coq-8.1pl2'
This looks a lot like my last installation of Coq. Your configure
script might not be as happy as it seems, especially if your system
shell is not bash: there is one test written in bash-specific syntax
([[ ... ]] instead of [ ... ]). Normally, this is fixed in the svn
version of coq. The godi package should have provided a patch too, but
my hard disk decided against it. This should be corrected by Monday. If
you can't wait that long, I don't recall exactly where the bashism is
located in the configure script, but your config.log should.
Hope this helps,
E tutto per oggi, a la prossima volta.
Virgile
