- From: "Alfonso Nishikawa" <alfonso.nishikawa AT gmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] I need help with ListSet
- Date: Thu, 13 Dec 2007 23:54:05 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=DGmaoVZQv0rrBCnXgvzG7jlysJ++H0s5E8AjPVA2oplj6KpErMFp+u7NYmMQD/UBkqLc/6DC/zp9nB0Mfeso72/URx2cWmsVo7UbnxWsXkP5T5jwDAcbYJ/WlSSIEJ+qIVlyVjABqzvh322+6+/6p9jFvkaRicobIIpNtrjNufQ=
Hi!
I'm a beginner and I have been trying to proof:
[code]
Require Import ListSet.
Variable A:Set.
Variable T:Set.
Axiom eq_dec_T:forall(tf1 tf2:T),{tf1=tf2}+{~tf1=tf2}.
Lemma a : forall (a:T) (x:set T), ~ set_In a (set_remove eq_dec_T a x).
[/code]
Until I realized it can't be proved because it's not true nor false. So I thought about other goal, prove this:
[code]
Variable a : T.
Variable x : set T.
Axiom anbx : ~ set_In a x.
Definition x1 := set_add eq_dec_T a x : set T.
Lemma aaa : ~ set_In a (set_remove eq_dec_T a x1).
unfold set_remove.
[/code]
and I get this:
~ set_In a
((fix set_remove (a : T) (x : set T) {struct x} : set T :=
match x with
| List.nil => empty_set T
| List.cons a1 x1 =>
if eq_dec_T a a1 then x1 else List.cons a1 (set_remove a x1)
end) a x1)
Why can't I do this: get 2 new subgoals with parameters 'a' and 'x1' subsituted in the function 'fix....' ?
If I could, I would have:
~ set_In a (empy_set T)
--- and
~ set_In a (eq_dec_T a a then x1 ...
and that is trivial...
In this second problem I had to put parameters as Variable's, Axiom and Definition because I have problems putting them as -> -> -> ¿how can I put then in that way?
If someone can help me I will be very grateful.
- [Coq-Club] I need help with ListSet, Alfonso Nishikawa
- Re: [Coq-Club] I need help with ListSet, Pierre Casteran
- [Coq-Club] integer constant notation,
Andrew McCreight
- Re: [Coq-Club] integer constant notation, Arnaud Spiwack
