- From: Andrew McCreight <andrew.mccreight AT yale.edu>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] integer constant notation
- Date: Tue, 18 Dec 2007 07:41:17 -0500 (EST)
Hello,
Is there some way to declare my own custom interpretation of integer constants in a scope, as are available in the nat and Z scopes? If I have a function Z_to_foo : Z -> foo, I'd like to be able to make, for instance, "4" automatically intepreted as "Z_to_foo 4" in a particular context. I looked around on the manual and the nat and Z libraries but couldn't find anything. Coercions sort of do what I want, but it doesn't seem like you can tie them to particular notation scopes. Or is this how nat and Z do it? Thanks!
-Andrew
- [Coq-Club] I need help with ListSet, Alfonso Nishikawa
- Re: [Coq-Club] I need help with ListSet, Pierre Casteran
- [Coq-Club] integer constant notation, Andrew McCreight
- Re: [Coq-Club] integer constant notation, Arnaud Spiwack
