coq-club - [Coq-Club] Re: rewriting by a relation in Set
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: rewriting by a relation in Set
  • Date: Mon, 17 Dec 2007 12:03:38 -0500
Pardon me if I am asking something obvious, but is it possible to use
'rewrite' with an equivalence relation with type A->A->Set instead of
A->A->Prop?
rewrite seems to work with identity, which is a Type analog of Leibniz equality defined in Coq.Init.Datatypes. Concerning other relations, it seems that currently one cannot declare a relation E : A -> A -> Set as a setoid relation; therefore, it cannot be used with rewrite. Of course, if it is possible to prove the theorem
forall (P : A -> Prop), P x -> forall y: A, E x y -> P y
then one can write an imitation of rewrite in Ltac, though it may not determine the subterms that are to be replaced by unification, as rewrite does.
At this moment I am not sure if it makes sense to have reflexive, symmetric and transitive relations in Set: after all, E x y may consist of many elements and E x y -> E y x only guarantees the existence of a function from E x y to E y x, not that the sets E x y and E y x are equal. Do you have an interesting example where rewriting a relation in Set makes sense?
Evgeny
