- To: Evgeny Makarov <emakarov AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: rewriting by a relation in Set
- Date: Tue, 18 Dec 2007 09:58:26 +0100
Evgeny Makarov wrote:
> then one can write an imitation of rewrite in Ltac, though it may not
> determine the subterms that are to be replaced by unification, as
> rewrite does.
Thanks for the tip. I'm sure there is some workaround for what I want to
do. Maybe the best is to modify the setoid code of Coq so that it works
with any type, not just Prop...?
> At this moment I am not sure if it makes sense to have reflexive,
> symmetric and transitive relations in Set: after all, E x y may
> consist of many elements and E x y -> E y x only guarantees the
> existence of a function from E x y to E y x, not that the sets E x y
> and E y x are equal. Do you have an interesting example where
> rewriting a relation in Set makes sense?
I am writing in Coq an interpreter for a programing language that is an
equational theory and I want to extract my theorems as ML code, so my
equality can't be in Prop. I also want to use as much automation as
possible, in particular the ring tactic, for which I need to have a setoid.
Is there any theoretical reason why setoids are limited to
Prop-relations in Coq? I have used them in context of Martin-Löf type
theory which has no Prop.
Thanks,
Danko
- [Coq-Club] rewriting by a relation in Set, Danko Iliḱ
- [Coq-Club] Re: rewriting by a relation in Set,
Evgeny Makarov
- Re: [Coq-Club] Re: rewriting by a relation in Set, Danko Iliḱ
Evgeny Makarov
