- To: Michael Day <mikeday AT yeslogic.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Induction principle for folding over lists
- Date: Fri, 28 Dec 2007 16:16:12 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=date:from:to:cc:subject:message-id:in-reply-to:references:organization:x-mailer:mime-version:content-type:content-transfer-encoding:sender; b=shMuQHlBvjmNjemk169lBpKeHDisckv/D1y759FsrMLcUFtltl2qLdS5X9JtMBkSpLsK+Efxl1NkuyZ9CzK61nRKgmHg6cdISTbOweJoA7KwtXqy00atWgHpQtvWqhYZwNxd2D/s3z3wPPFZ9q1DVpTilOC3onbieGdvNj+XbOw=
- Organization: CNAM
On Fri, 28 Dec 2007 00:26:23 -0800 (PST)
Michael Day
wrote:
> Hi,
> I'm new to Coq and having trouble proving some properties of this function:
> Fixpoint fold (A:Set) (f:A -> A -> A) (a:A) (xs:list A) : list A :=
> match xs with
> | nil => nil
> | x::xs0 => (f a x)::(fold A f (f a x) xs0)
> end.
> The function transforms a list by applying a function to each element. It's
> different from map, as there is an accumulator threaded through the list.
> ("fold" isn't the right name for it, but I'm not sure what is; in Mercury
> there is a function a bit like this called "map_foldl").
> I've defined an inductive predicate that represents the results of
> transforming a list with fold:
> Inductive folded (A:Set) (f:A -> A -> A) : A -> list A -> list A -> Prop :=
> | fold_nil : forall (a:A), folded A f a nil nil
> | fold_cons : forall (a x0:A)(xs0 xs:list A),
> folded A f (f a x0) xs0 xs -> folded A f a (x0::xs0) ((f a x0)::xs).
> But I am utterly unable to prove that the function actually conforms to it:
> Theorem foldl_folded : forall (A:Set) (f:A -> A -> A) (a:A) (xs:list A),
> folded A f a xs (foldl A f a xs).
> Proof.
> induction xs ; simpl.
> It seems that the induction principle for lists generates the wrong
> hypothesis in this case, which makes it useless for proving the theorem. A
> similar theorem for a "map" function with no accumulator argument is trivial
> to prove.
> I tried making up an induction scheme like this:
> Theorem foldl_ind : forall (A:Set) (f:A -> A -> A) (P : A -> list A ->
> Prop),
> (forall (a:A), P a nil) ->
> (forall (a x:A) (xs:list A), P (f a x) xs -> P a (x::xs)) ->
> (forall (a:A) (xs:list A), P a xs).
You should try the Function construction as follows:
Function fold (A:Set) (f:A -> A -> A) (a:A) (xs:list A) {struct xs} : list A
match xs with
| nil => nil
end.
folded A f a xs (fold A f a xs).
Proof.
intros A f a xs;
functional induction (fold A f a xs).
apply fold_nil.
apply fold_cons. exact IHl.
Qed.
Julien Forest
- [Coq-Club] Induction principle for folding over lists, Michael Day
- Re: [Coq-Club] Induction principle for folding over lists, Catherine Dubois
- Re: [Coq-Club] Induction principle for folding over lists, Nicolas Marti
gbush
- Re: [Coq-Club] Induction principle for folding over lists, Matthieu Sozeau
- Re: [Coq-Club] Induction principle for folding over lists, Julien Forest
- Re: [Coq-Club] Induction principle for folding over lists, Michael Day
