- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Induction principle for folding over lists
- Date: Fri, 28 Dec 2007 17:21:47 +0100
The fix tactic essentially corresponds with Fixpoint functions in Coq, where
the numeric argument is the index of the argument that will be structurally
decreasing. It can be tricky to use, since you must guarantee yourself that
the primary argument is structurally decreasing, and you will not get
confirmation that it is or isn’t until Qed.
I am also relatively new to Coq, so there may be a more elegant way to
approach this, but if I get stuck with an induction principle that doesn't
seem to do what I want, I usually go to "fix."
Hi Greg,
The induction principle actually does what you want in this case, it's just that you have to quantify your goals carefully.
The problem boils down to: do you want to prove
A (f : A -> A -> A) (a : A) |- forall (xs : list a), folded A f xs (fold A f a xs) or
A (f : A -> A -> A) |- forall (xs : list a), forall (a : A), folded A f xs (fold A f a xs).
In the first case, you will not get a general enough induction hypothesis, as the accumulator changes in the definition of fold.
However, in the second case it could be overkill to quantify on all "a : A" if a is actually a parameter of fold like A and f are.
Matthieu Sozeau
http://www.lri.fr/~sozeau
- [Coq-Club] Induction principle for folding over lists, Michael Day
- Re: [Coq-Club] Induction principle for folding over lists, Catherine Dubois
- Re: [Coq-Club] Induction principle for folding over lists, Nicolas Marti
gbush
- Re: [Coq-Club] Induction principle for folding over lists, Matthieu Sozeau
- Re: [Coq-Club] Induction principle for folding over lists, Julien Forest
- Re: [Coq-Club] Induction principle for folding over lists, Michael Day
