coq-club - Re: [Coq-Club] Oracles in Coq?
chronological Thread
  • From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
  • To: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Oracles in Coq?
  • Date: Fri, 07 Mar 2008 13:09:08 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=FS/o42hZP0pq1XFWHmvR6noxnw+BTAx4/R/hbHq8qT/DN7nHwBEtN2sawIynFt4/Hv1agDmXMZMeXDOsMuWWCYXL6uL27pVtA2/T6NMG2RvF72mlFIefS0SeH1OfooMiBP4lMYBoTxRmUWFLY3bEZOfD7zEy+Rlvf8niW8njbhs=
Hello,
This is can't be done without heavy boilerplate at the time, as far as I'm aware. The only thing I can come up with is changing the Program Obligation Tactic so that it tries your oracle as well when you need it.
However, you are not the first (and probably not the last) to come up with such an idea. Future evolutions of the system might include this possibility (it is not clear to me whether it is possible to do in a reasonable amount of code in the current architecture, it could create some dependency mayhem, but on the architecture I'm trying to get done currently it should be doable. I think. I hope.).
I suggest you submit a formal feature wish to the bug tracking system.
Arnaud
Guillaume Melquiond a écrit :
Hi,
I am looking for a way to express oracles; in other words, information
that come from outside a lambda-term. See the toy example below:
        Definition cbrt_aux x y :=
          let y' := Zsucc y in
          if andb (Zle_bool (y * y * y) x) (Zlt_bool x (y' * y' * y'))
          then Some y else None.
Notation cbrt := (fun x => cbrt_aux x _).
Definition test := cbrt 20%Z.
This defines a function cbrt that returns the integer cube root of its
argument, if prepended by "Some". Its proof of correctness (not shown
here) is trivial, since it is by definition.
Obviously and unfortunately, Coq will complain that it is not able to
infer the placeholder (the actual cube root) in the definition of
"test". The placeholder can be filled manually though:
        Definition test : option Z.
        refine (cbrt 20%Z).
        exact 2%Z. (* <-- here *)
        Defined.
What I would like is for Coq to fill the placeholder automatically, for
instance by calling a tactic. To clarify, the following would be fine to
me:
        fun x => cbrt_aux x ltac:(magic_cbrt x).
Coq would consider the second parameter as "_", but if it needs its
value, it would call the tactic (which could possible call an external
program with the XML mechanism) and then stores the result in the
lambda-term.
Is it possible to achieve this trick with the existing system or do I
need to modify Coq?
Best regards,
Guillaume
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
