- From: Benjamin Gregoire <Benjamin.Gregoire AT sophia.inria.fr>
- Cc: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Managing memory from Coq - Correction
- Date: Fri, 07 Mar 2008 12:56:02 +0100
Frédéric Besson wrote:
Just to go furthermore in the direction of Frederic,
On my laptop, the whole script takes 300s.
You can do the same using N (and not nat) for the computation.
In my computer the compilation takes less that 1 second :) .
Benjamin
Inductive bit:Set:= v0:bit | v1:bit.
Require Import NArith.
Definition bit2_N0 b := match b with v0 => N0 | v1 => 1%N end.
Definition bit2_N b := match b with v0 => Ndouble | v1 => Ndouble_plus_one
end.
Coercion bit2_N0 : bit >-> N.
Definition comp1(b:bit):bit:=match b with v0 => v1 | v1 => v0 end.
Definition add11(b1 b2 b3:bit):=
match (b1,b2,b3) with
| (v0,v0,_) => (v0,b3)
| (v1,v1,_) => (v1,b3)
| _ => (b3,comp1 b3) end.
Inductive byte:Set:=bt:bit->bit->bit->bit->bit->bit->bit->bit->byte.
Definition byte2N b :=
match b with
| bt b7 b6 b5 b4 b3 b2 b1 b0 =>
bit2_N b0 (bit2_N b1 (bit2_N b2 (bit2_N b3 (bit2_N b4 (bit2_N b5 (bit2_N
b6 b7))))))
end.
Coercion byte2N : byte >-> N.
Definition add88(b1 b2:byte):=
match b1 with bt b17 b16 b15 b14 b13 b12 b11 b10 =>
match b2 with bt b27 b26 b25 b24 b23 b22 b21 b20 =>
match add11 b10 b20 v0 with (c0,b30) =>
match add11 b11 b21 c0 with (c1,b31) =>
match add11 b12 b22 c1 with (c2,b32) =>
match add11 b13 b23 c2 with (c3,b33) =>
match add11 b14 b24 c3 with (c4,b34) =>
match add11 b15 b25 c4 with (c5,b35) =>
match add11 b16 b26 c5 with (c6,b36) =>
match add11 b17 b27 c6 with (c7,b37) =>
(c7,bt b37 b36 b35 b34 b33 b32 b31 b30)
end end end end end end end end
end
end
Definition one := bt v0 v0 v0 v0 v0 v0 v0 v1.
Definition zero :=bt v0 v0 v0 v0 v0 v0 v0 v0.
Definition max_int := bt v1 v1 v1 v1 v1 v1 v1 v1.
Section ForAll.
Variable f : byte -> bool.
Definition prover1 b7 b6 b5 b4 b3 b2 b1 :=
andb (f (bt b7 b6 b5 b4 b3 b2 b1 v0)) (f (bt b7 b6 b5 b4 b3 b2 b1 v1)).
Lemma prover1_spec : forall b7 b6 b5 b4 b3 b2 b1,
prover1 b7 b6 b5 b4 b3 b2 b1 = true -> forall b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover1;intros.
case_eq (f (bt b7 b6 b5 b4 b3 b2 b1 v0));intros Heq;rewrite Heq in H;try
discriminate.
destruct b0;trivial.
Qed.
Definition prover2 b7 b6 b5 b4 b3 b2 :=
andb (prover1 b7 b6 b5 b4 b3 b2 v0) (prover1 b7 b6 b5 b4 b3 b2 v1).
Lemma prover2_spec : forall b7 b6 b5 b4 b3 b2,
prover2 b7 b6 b5 b4 b3 b2 = true -> forall b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover2;intros.
apply prover1_spec.
case_eq (prover1 b7 b6 b5 b4 b3 b2 v0);intros Heq;rewrite Heq in H;try
discriminate.
destruct b1;trivial.
Qed.
Definition prover3 b7 b6 b5 b4 b3 :=
andb (prover2 b7 b6 b5 b4 b3 v0) (prover2 b7 b6 b5 b4 b3 v1).
Lemma prover3_spec : forall b7 b6 b5 b4 b3,
prover3 b7 b6 b5 b4 b3 = true -> forall b2 b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover3;intros.
apply prover2_spec.
case_eq (prover2 b7 b6 b5 b4 b3 v0);intros Heq;rewrite Heq in H;try
discriminate.
destruct b2;trivial.
Qed.
Definition prover4 b7 b6 b5 b4 :=
andb (prover3 b7 b6 b5 b4 v0) (prover3 b7 b6 b5 b4 v1).
Lemma prover4_spec : forall b7 b6 b5 b4,
prover4 b7 b6 b5 b4 = true -> forall b3 b2 b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover4;intros.
apply prover3_spec.
case_eq (prover3 b7 b6 b5 b4 v0);intros Heq;rewrite Heq in H;try
discriminate.
destruct b3;trivial.
Qed.
Definition prover5 b7 b6 b5 :=
andb (prover4 b7 b6 b5 v0) (prover4 b7 b6 b5 v1).
Lemma prover5_spec : forall b7 b6 b5,
prover5 b7 b6 b5 = true -> forall b4 b3 b2 b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover5;intros.
apply prover4_spec.
case_eq (prover4 b7 b6 b5 v0);intros Heq;rewrite Heq in H;try discriminate.
destruct b4;trivial.
Qed.
Definition prover6 b7 b6 :=
andb (prover5 b7 b6 v0) (prover5 b7 b6 v1).
Lemma prover6_spec : forall b7 b6,
prover6 b7 b6 = true -> forall b5 b4 b3 b2 b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover6;intros.
apply prover5_spec.
case_eq (prover5 b7 b6 v0);intros Heq;rewrite Heq in H;try discriminate.
destruct b5;trivial.
Qed.
Definition prover7 b7 :=
andb (prover6 b7 v0) (prover6 b7 v1).
Lemma prover7_spec : forall b7,
prover7 b7 = true -> forall b6 b5 b4 b3 b2 b1 b0, f (bt b7 b6 b5 b4 b3 b2
b1 b0) = true.
Proof.
unfold prover7;intros.
apply prover6_spec.
case_eq (prover6 b7 v0);intros Heq;rewrite Heq in H;try discriminate.
destruct b6;trivial.
Qed.
Definition prover := andb (prover7 v0) (prover7 v1).
Lemma prover_proves : prover = true -> forall b, f b = true.
Proof.
unfold prover;intros.
destruct b; apply prover7_spec.
case_eq (prover7 v0);intros Heq;rewrite Heq in H;try discriminate.
destruct b;trivial.
Qed.
End ForAll.
Require Import Ndec.
Open Scope N_scope.
Definition final_test b1 b2 :=
match (add88 b1 b2) with
| (c,b) => Neqb (b1 + b2) (c*256 + b)
end.
Definition checker :=
prover (fun b1 => prover (fun b2 => final_test b1 b2)).
Lemma checker_proves : checker = true -> forall b1 b2, match (add88 b1 b2)
with (c,b) =>
b1+b2= c*256+b end.
Proof.
unfold checker;intros.
assert (W:=prover_proves _ H b1).
assert (W1 := prover_proves _ W b2);simpl in W1.
unfold final_test in W1;destruct (add88 b1 b2) as (c,b).
rewrite (Neqb_complete _ _ W1);trivial.
Qed.
Theorem add88_correct_N:forall (b1 b2:byte),
match (add88 b1 b2) with (c,b) => b1+b2=c*256+b end.
Proof.
apply checker_proves.
Time vm_compute.
reflexivity.
Time Qed.
(* If you really want nat *)
Require Import Nnat.
Definition bit2nat(b:bit):nat:=match b with v0 => 0%nat | v1 => 1%nat end.
Coercion bit2nat:bit>->nat.
Definition byte2nat(b:byte):nat:=
match b with bt b7 b6 b5 b4 b3 b2 b1 b0 =>
(((((((b7*2+b6)*2+b5)*2+b4)*2+b3)*2+b2)*2+b1)*2+b0)%nat end.
Coercion byte2nat:byte>->nat.
Definition checker_nat :=
prover (fun b => Neqb (N_of_nat (byte2nat b)) b).
Lemma checker_nat_proves : forall b,
(N_of_nat (byte2nat b)) = b.
Proof.
cut (prover (fun b => Neqb (N_of_nat (byte2nat b)) b) = true).
intros;assert (W:=prover_proves _ H b);simpl in W.
apply (Neqb_complete _ _ W);trivial.
vm_compute;reflexivity.
Qed.
Theorem add88_correct:forall (b1 b2:byte),
match (add88 b1 b2) with (c,b) => (b1+b2=c*256+b)%nat
end.
Proof.
intros.
assert (W:= add88_correct_N b1 b2).
rewrite <- (nat_of_N_of_nat (b1+b2)%nat).
rewrite N_of_plus.
repeat rewrite checker_nat_proves.
rewrite W.
rewrite <- (nat_of_N_of_nat (c * 256 + b)%nat).
rewrite N_of_plus.
destruct c;trivial.
Qed.
- [Coq-Club] Managing memory from Coq - Correction, marko
- Re: [Coq-Club] Managing memory from Coq - Correction,
Lionel Elie Mamane
- Message not available
- Re: [Coq-Club] Managing memory from Coq - Correction, Lionel Elie Mamane
JAEGER, Eric (SGDN)
Frédéric Besson
- Re: [Coq-Club] Managing memory from Coq - Correction, Benjamin Gregoire
JAEGER, Eric (SGDN)
marko
- [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Roland Zumkeller
- Re: [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Eduardo Gimenez
marko
JAEGER, Eric (SGDN)
Frédéric Besson
Lionel Elie Mamane
