coq-club - Re: [Coq-Club] Heterogeneous equality?
chronological Thread
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Heterogeneous equality?
  • Date: Thu, 20 Mar 2008 13:09:49 -0400
Edsko de Vries wrote:
If we now do
  Eval compute in g 0.
we get
     = match
         match minus_n_n 0 in (_ = y) return (y = 0) with
         | refl_equal => refl_equal 0
         end in (_ = y) return (T y)
       with
       | refl_equal =>
           match minus_n_n 0 in (_ = y) return (T y) with
           | refl_equal => T0
           end
       end
     : T 0
whereas I'd much rather just get T0!
It looks like [minus_n_n] is set to be opaque, which means that the definitional equality may not expand [minus_n_n] to its definition, so no application of it can ever reduce to a [refl_equal] prof. You might be able to use the [Transparent] vernacular command, but that will fail if [minus_n_n] was originally defined opaquely. In that case, you'll need to redefine it transparently (end a definition with [Defined] instead of [Qed]). Alternatively, you can bring in an axiom and rewrite with [UIP_refl], a theorem you can get by importing [Eqdep] from the standard library.
