- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Heterogeneous equality?
- Date: Thu, 20 Mar 2008 13:28:15 -0400 (EDT)
On Thu, 20 Mar 2008, Edsko de Vries wrote:
Eval compute in g 0.
we get
= match
As Adam noted, the problem is that minus_n_n is opaque, and is not available for computation. These sorts of type-casts are a bit of a problem in Coq. I would be inclined to write my own transparent version of minus_n_n, but I'm not sure if there are better ideas.
whereas I'd much rather just get T0! I'm not sure what to do to make it
give me T0. Also, I'd like to be able to prove the following lemma:
Lemma l1 : forall n, g n = T0.
We can prove something more general.
Require Import Eqdep_dec.
Lemma l1 : forall x : T 0, T0 = x.
intros n.
change (T0) with (eq_rec 0 T T0 0 (refl_equal 0)).
generalize (refl_equal 0).
revert n.
set (z:=0).
unfold z at 2 5.
generalize z.
clear z.
intros z [] e.
pattern e.
apply (K_dec).
intros x y.
destruct (eq_nat_dec x y); auto.
reflexivity.
Qed.
Maybe more clever Coq people know how to make a shorter proof.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Heterogeneous equality?, Edsko de Vries
- Re: [Coq-Club] Heterogeneous equality?, Adam Chlipala
- Re: [Coq-Club] Heterogeneous equality?, roconnor
Adam Chlipala
- Re: [Coq-Club] Heterogeneous equality?, Edsko de Vries
Adam Chlipala
