- To: coq-club AT pauillac.inria.fr
- Cc: urbanc AT in.tum.de
- Subject: [Coq-Club] One-Day Tutorial on Nominal Isabelle at IJCAR 2008
- Date: Fri, 28 Mar 2008 06:16:23 +0100
Dear Coq users,
There will be a tutorial on Nominal Isabelle at IJCAR 2008
(see announcement below).If you have missed the recent
Coq-workshop at POPL, then this is your second chance for a
tutorial about using a proof assistant, though it is Isabelle ;o)
If you have have been there, the tutorial will demonstrate an
alternative approach to writing POPL papers.
Best wishes,
Christian Urban
Time: 11th August (just before main conference)
Overview:
Dealing with binders, renaming of bound variables, capture-avoiding
substitution, etc., is very often a major problem in formal proofs about the
lambda-calculus and programming language theory. Nominal Isabelle provides an
infrastructure for reasoning conveniently about bound variables and
alpha-equivalence classes in the proof assistant Isabelle. The aim of this
tutorial is to give participants a reading knowledge of nominal techniques and
allow them to start using Nominal Isabelle in their own work. The tutorial
will be hands-on and therefore participants are encouraged to bring their own
laptop.
Programme:
The tutorial will be organised around four sessions:
Session I: basics, substitution lemma, Isar proof language
Session II: strong induction principles, contexts with holes, beta-reduction
Session III: variable convention and rule inductions, evaluation relation
Session IV: function definitions, freshness, support
Target audience for the tutorial:
Researchers and doctoral students who want to use Nominal Isabelle to
formalise proofs from the lambda-calculus, from programming language theory or
from proof theory, such as type soundness, Church Rosser, strong normalisation
and so on. The tutorial is designed for people who have not necessarily used
Isabelle or Nominal Isabelle before, nor have used any other proof assistant.
HTML version of this announcement:
http://isabelle.in.tum.de/nominal/activities/nominal-ijcar08/
- [Coq-Club] One-Day Tutorial on Nominal Isabelle at IJCAR 2008, Christian Urban
