coq-club - [Coq-Club] Matching non-empty vectors
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Matching non-empty vectors
  • Date: Fri, 28 Mar 2008 19:07:07 +1100
Hi,
I have defined a simple vector type and a function to get the first element of non-empty vectors as follows:
Inductive vec (A:Type) : nat -> Type :=
    | Vnil : vec A 0
    | Vcons : forall (a:A) (n:nat), vec A n -> vec A (S n).
Definition get_first (A:Type) (n:nat) (v:vec A (S n)) (default:A) : A :=
    match v with
    | Vnil => default    (* I want to delete this line *)
    | Vcons a _ _ => a
    end.
Coq prevents me from calling get_first with an empty vector, so the Vnil case will never be matched and the default value will never be used. However, Coq does not permit me to omit this case:
Error: Non exhaustive pattern-matching: no clause found for pattern Vnil
This is incredibly frustrating. Why does Coq think that "Vnil" is an inhabitant of "vec (S n)"? After reading Conor McBride's papers on Epigram I expect the system to understand that 0 <> S n :)
The Vhead function in the Bvector module in the standard library uses the inversion tactic instead, but that seems to generate a very large and complicated definition for something that should be quite simple.
Best regards,
Michael
Print XML with Prince!
http://www.princexml.com
