coq-club - Re: [Coq-Club] How to compare hypotheses over subgoals
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: Yves.Bertot AT sophia.inria.fr
  • Subject: Re: [Coq-Club] How to compare hypotheses over subgoals
  • Date: Sun, 30 Mar 2008 11:22:06 +0200 (CEST)
  • Importance: Normal
> Can you turn your problem around so that all cases appear in the same
> goal?
No, I can't because these hypotheses are some of the most important thinks
in my system. But I try to find a way to "merge" subgoals. So, if I have
several subgoals with the same statement to prove and if every subgoal
contain hypothesis with the same name but (maybe) with the different
values, for example:
subgoal 1:
H : x=5
...other hypotheses...
y=z
subgoal 2:
H : x=6
y=z
can I somehow "merge" this two subgoals in subgoal 3 and then in subgoal 3
to check is the values of parameter x is the same. So, subgoal 3 has to
look like this:
subgoal 3:
H1 : x=5
H2 : x=6
y=z
> As a side note, the example you give is very strange.  Do you believe that
> by assuming
> H: lista_predikata = predikat a1 b2 a3 c4 :: predikat d1 c2 a3 c4::nil
> you are actually asserting that predikat a1 b2 a3 c4 hold?  This is not
> the case!
This is not important for me. Hypothesis
is for me just a way to record some values and lista_predikata is growing
up through the proof tree. I just need to read from this hypothesis some
records.
Thank you very much,
Marko Malikoviæ
