- To: Matthieu Sozeau <sozeau AT lri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Program Fixpoint's binding behavior
- Date: Tue, 27 May 2008 11:13:23 +0100
Matthieu Sozeau wrote:
This is not a bug, but a common (documented) problem with structurally recursive definitions made with Program. If you finish an obligation in which the recursive prototype appears you should not use Qed but Defined, making the proof transparent so that the guardness check can be done. If you do that, you will find that you are actually doing non-structurally smaller calls in your obligation (calling [f (S n1)] at some point, or [f 0]).
The problem here is that you have a recursive call in your goal, which you should destruct before trying to solve the goal, using [destruct (f n0)] for example. After fixing that, your definition goes through.
Mattieu--Great tips, thanks. This alternative proof worked out:
Program Fixpoint f (n:nat) : {m | n < m} :=
match n with
| 0 => 1
| S n => S(f n)
end.
Next Obligation.
destruct (f n0).
induction n0.
apply lt_n_S; trivial.
simpl; apply lt_n_S; trivial.
Defined.
The original, for reference:
Require Import Arith.
match n with
| 0 => 1
| S n => S(f n)
end.
Next Obligation.
induction n0.
apply lt_n_S; destruct (f 0); trivial.
destruct (f (S n0)); simpl; apply lt_n_S; trivial.
Qed.
I suppose it was the [destruct (f 0)] in the original that caused problems; probably it couldn't determine that 0 was a subterm of the argument in that case.
Cheers,
Ezra
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
- [Coq-Club] Program Fixpoint's binding behavior, Ezra Cooper
- Re: [Coq-Club] Program Fixpoint's binding behavior,
Matthieu Sozeau
- Re: [Coq-Club] Program Fixpoint's binding behavior, Ezra Cooper
Matthieu Sozeau
