coq-club - [Coq-Club] The 'Function' feature anomaly.
chronological Thread
  • From: Hermann Lehner <hermann.lehner AT inf.ethz.ch>
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] The 'Function' feature anomaly.
  • Date: Wed, 28 May 2008 13:37:44 +0200
Hello all,
Some time ago (Mon, 30 Jul 2007 18:07:18 +0200), J.-F. Dufourd came across the following issue.
---snip----
Function div(a b:nat){measure (fun m:nat=>m) a}:nat:=
  if eq_nat_dec b 0 then 0
  else if (le_lt_dec b a) then (div (a-b) b) + 1 else 0.
Proof. intros. omega. Defined.
is refused with the message:
"Anomaly: Cannot create equation Lemma. Please report".
---snip----
Anyone having an answer on that, as I have the same problem with a much larger definition. The little example above still does not work with Coq 8.1pl3.
Does someone know which part of the function definition triggers this anomaly, so that it can be bypassed?
Thanks!
Best regards
  Hermann Lehner
http://www.hermann-lehner.com
