- From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- To: Matthieu Sozeau <sozeau AT lri.fr>
- Cc: frederic.blanqui AT loria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: allowing non-structurally terminating functions ?
- Date: Sun, 15 Jun 2008 13:29:47 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject :references:in-reply-to:content-type:content-transfer-encoding :sender; b=T6Z/RIRDhRZVktKGPUZzzgTN/2o6Fg9NdG+zSUUNZbc4HyZImD8Ex3wyKA52n9TdUL ZUSDFyGJab7UWvasH6E1JZLS1tzBQaATTPZCMnUg8cWe5A9KZ8OJUWSm707hUNZxVie6 CJcFtr1qOuoqN1uG7xB+YRhvQDnE4/918xzqo=
Well, most non structurally recursive functions in Coq lead to non-termination, for instance:
Actually, one would still need to tell on which argument to recurse, as the reduction functions need this to decide when to unfold. So I think a { general x } annotation would be the right way to do it. I'm willing to make the change (I have a patch somewhere doing that already), but maybe there are some arguments against it?
F x y :=
if x < y then
else
F (S x) y
F X (S Y) has a normal form but is not strongly normalizing
F (S X) (S Y) doesn't have a normal form.
You need to do some transformation to recover termination (for instance my suggested :
F x y :=
( if x < y then fun _ => 0 then fun G => G (S x) y ) F
If it is understood that this sort of function need a lot of care, we might as well decide arbitrarily that iota-reduction watches the first argument everytime (it would be quite of an interesting accident that choosing another argument would be of any interest whatsoever). Anyway, the need to check that a particular argument is constructed before unfolding the fixpoint is an artefact of structural recursion, therefore we shouldn't need any for non-structural recursion.
I personnally have no problem with an Unsafe Fixpoint feature. It's nothing worse than using "Axiom" anyway (plus it doesn't block reduction, so it's even better). As long as when I Print an Unsafe Fixpoint, I can see it is such (and more generally, that it's an accessible information to the kernel).
Arnaud Spiwack
- [Coq-Club] allowing non-structurally terminating functions ?, frederic . blanqui
- Re: [Coq-Club] allowing non-structurally terminating functions ?, Johannes Waldmann
Julien Forest
- Re: [Coq-Club] allowing non-structurally terminating functions ?, frederic . blanqui
- [Coq-Club] Re: allowing non-structurally terminating functions ?,
frederic . blanqui
- Re: [Coq-Club] Re: allowing non-structurally terminating functions ?,
Matthieu Sozeau
- Re: [Coq-Club] Re: allowing non-structurally terminating functions ?, Arnaud Spiwack
Pierre Letouzey
- Re: [Coq-Club] Re: allowing non-structurally terminating functions ?, Benjamin Werner
Matthieu Sozeau
