- To: <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Automated generation of lemmas
- Date: Wed, 18 Jun 2008 17:35:54 +0800
- Organization: National University of Singapore
Hi,
Consider the
following toy example:
CoInductive
a:nat->Prop := a1: a O | a2: forall n, a n -> a (S (S (S (S
n)))).
Coinductive
b:nat->Prop := b1: b O | b2: forall n, b n -> b (S (S
n)).
Goal forall n, a n
-> b n.
I can't use elim for
coinductive definitions. So the only solution I found was to prove this
auxilliary lemma:
Lemma L: forall n, a
n -> n=O \/ exists m, (S (S (S (S m))))=n /\ a m. (* easily proven using
cofix and destruct*)
I have the following
questions:
1) Is there a more
straightforward way to prove the above goal, without the auxilliary
theorem?
2) In fact, the
auxilliary theorem might be useful in a lot of other situations, so I may want
to define and prove this type of lemma for each of my inductive/coinductive
definitions. Is there some sort of scripting tool that would allow me
to program a macro or procedure whose parameter would be a, and which would
automate the process of generating this type of lemma and its
proof?
Thanks in
advance,
Razvan
- [Coq-Club] Automated generation of lemmas, Razvan Voicu
- Re: [Coq-Club] Automated generation of lemmas, Benjamin Werner
