- From: Benjamin Werner <benjamin.werner AT polytechnique.fr>
- To: <razvan AT comp.nus.edu.sg>
- Cc: <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Automated generation of lemmas
- Date: Wed, 18 Jun 2008 12:01:45 +0200
Hi,
Your lemma actually shows the equivalence with the inductive versions
of the predicates.
The direct proof goes through all right for me (I do not think it is a question
of Coq versions, but this is with 8.2beta) :
CoInductive a:nat->Prop := a1: a O | a2: forall n, a n -> a (S (S (S (S n)))).
CoInductive b : nat->Prop := b1: b O | b2: forall n, b n -> b (S (S n)).
Goal forall n, a n -> b n.
cofix chr.
intros [|p].
intros; constructor.
inversion 1.
constructor; constructor.
apply chr.
assumption.
Qed.
Le 18 juin 08 à 11:35, Razvan Voicu a écrit :
Hi,
Consider the following toy example:
Coinductive b:nat->Prop := b1: b O | b2: forall n, b n -> b (S (S n)).
I can't use elim for coinductive definitions. So the only solution I found was to prove this auxilliary lemma:
Lemma L: forall n, a n -> n=O \/ exists m, (S (S (S (S m))))=n /\ a m. (* easily proven using cofix and destruct*)
I have the following questions:
1) Is there a more straightforward way to prove the above goal, without the auxilliary theorem?
2) In fact, the auxilliary theorem might be useful in a lot of other situations, so I may want to define and prove this type of lemma for each of my inductive/coinductive definitions. Is there some sort of scripting tool that would allow me to program a macro or procedure whose parameter would be a, and which would automate the process of generating this type of lemma and its proof?
Thanks in advance,
Razvan
- [Coq-Club] Automated generation of lemmas, Razvan Voicu
- Re: [Coq-Club] Automated generation of lemmas, Benjamin Werner
