coq-club - Re: [Coq-Club] Codata: problem with guardedness condition?
chronological Thread
  • To: Samuel Bronson <naesten AT gmail.com>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Codata: problem with guardedness condition?
  • Date: Tue, 01 Jul 2008 11:41:25 +0200
Dear Samuel,
I did not see a question in your message, but yes, your program violates the guardedness
condition.
The guardedness condition for corecursive definitions is much more restrictive than
the "well-definedness" conditions for Haskell and other lazy programming languages.
Simply put, a co-recursive definitions is guarded if all recursive references to the
function you are defining appear in branches of pattern-matching constructs and
as sub-terms of constructors of the same co-recursive type (or constructors of
a co-recursive type that was defined co-inductively in a mutual definition with
their type), with at least one constructor involved.
Your definition violates this condition, because co-recursive calls appear under
a call to dPlus, and dPlus is neither a pattern-matching construct nor a constructor
of the co-inductive type.
I am aware of work to circumvent the limitations of guardedness to get closer to
"general corecursion". The experiments done in my team only make it possible
to cope with the cases where functions are not accepted because the "at least one
constructor" clause in not satisfied. But your code does not fall in this category. It
has been nagging us for a long time, but we haven't found a way in yet.
I believe work by Miculan and di Giantonio (FOSSACS'04 ?) and recent work
published by Christine Paulin on her Web page
http://www.lri.fr/~paulin/PUBLIS/paulin07kahn.pdf
are related to this topic.
I hope this helps,
Yves
Samuel Bronson wrote:
I'm trying to implement
http://conal.net/blog/posts/beautiful-differentiation/ but having
trouble with the guardedness condition -- at least, that's what I
think it must be. My latest attempt is:
Section Foo.
  Variable N : Type.
  Variable zero : N.
  Variable plus : N -> N -> N.
  Variable times : N -> N -> N.
  Variable opp : N -> N.
  Infix    "+"   := plus    : N_scope.
  Infix    "*"   := times   : N_scope.
  Notation "- x" := (opp x) : N_scope.
  Bind Scope N_scope with N.
  (* <roconnor> SamB: how about
   *   x@(D x0 x') * y@(D y0 y') = D (x0 * y0) (x' * y) + D 0 (x * y')
  CoInductive Dif :=
   D : N -> Dif -> Dif.
  Delimit Scope Dif_scope with Dif.
  Bind Scope Dif_scope with Dif.
  CoFixpoint dZero := D zero (dZero).
  CoFixpoint dOpp (x : Dif) : Dif :=
    match x with
      D x0 x' => D (-x0) (-x')%Dif
    end
  where "- x" := (dOpp x).
  CoFixpoint dPlus (x y : Dif) : Dif :=
    match x, y with
      D x0 x', D y0 y' => D (x0 + y0) (x' + y')%Dif
    end
  where "x + y" := (dPlus x y).
  CoFixpoint dTimes (x y : Dif) : Dif :=
    match x, y with
      D x0 x', D y0 y'
        => D (x0 * y0) (x' * y + x * y')
    end%Dif
  where "x * y" := (dTimes x y).
End Section.
but the definition of dTime fails, with the error message:
Error:
Recursive definition of dTimes is ill-formed.
In environment
N : Type
zero : N
plus : N -> N -> N
times : N -> N -> N
opp : N -> N
dTimes : Dif -> Dif -> Dif
x : Dif
y : Dif
x0 : N
x' : Dif
y0 : N
y' : Dif
Unguarded recursive call in
"cofix dPlus (x y : Dif) : Dif :=
   match x with
   | D x0 x' => match y with
                | D y0 y' => D (x0 + y0) (x' + y')
                end
   end".
Recursive definition is:
"fun x y : Dif =>
 match x with
 | D x0 x' =>
     match y with
     | D y0 y' => D (x0 * y0) (dTimes x' y + dTimes x y')
     end
 end".
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
