coq-club - Re: [Coq-Club] embed axiom in a definition
chronological Thread
  • To: T.Tsokos AT cs.bham.ac.uk
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] embed axiom in a definition
  • Date: Fri, 04 Jul 2008 09:14:21 -0400
 wrote:
 wrote:
> I am trying to do the following. Assuming I define 2 axioms:
> Axiom first_axiom : forall (A: ...) ... .
> Axiom second_axiom: forall (A: ...) ... .
> Let's say I would like to define a construct of a natural number > "embedding" the two properties described by the above axioms. Is there > a way to do something like that (as if in sig, where the axioms > provide a certificate):
> Definition nat_embedded := {n:nat | first_axiom holds /\ second_axiom > holds}.
> so that I can prove properties on "nat_embedded" later on, that > preserve the two axioms as well?
It is puzzling that you bother to maintain proofs that the axioms hold for particular natural numbers, when you have already asserted that the axioms hold for all naturals. With the axioms in place, we can prove that [nat_embedded] is isomorphic to [nat].
Interesting point. However, by "embedding" these axioms, I (think I) am trying define/describe a specific subset of natural numbers and prove some properties for this subset. If the property holds for the superset, I reckon it doesn't automatically hold for the subset too.
If you are using the keyword [Axiom], then you are _not_ "embedding the axioms." You are asserting them for all naturals. Maybe previous replies have led you away from using the [Axiom] keyword, in which case all is well. ;-)
