- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] embed axiom in a definition
- Date: 04 Jul 2008 10:50:03 +0100
On Jul 3 2008, Adam Chlipala wrote:
T.Tsokos AT cs.bham.ac.uk
wrote:
> I am trying to do the following. Assuming I define 2 axioms:
> Axiom first_axiom : forall (A: ...) ... .
> Axiom second_axiom: forall (A: ...) ... .
> Let's say I would like to define a construct of a natural number > "embedding" the two properties described by the above axioms. Is there > a way to do something like that (as if in sig, where the axioms > provide a certificate):
> Definition nat_embedded := {n:nat | first_axiom holds /\ second_axiom > holds}.
> so that I can prove properties on "nat_embedded" later on, that > preserve the two axioms as well?
It is puzzling that you bother to maintain proofs that the axioms hold for particular natural numbers, when you have already asserted that the axioms hold for all naturals. With the axioms in place, we can prove that [nat_embedded] is isomorphic to [nat].
Interesting point. However, by "embedding" these axioms, I (think I) am trying define/describe a specific subset of natural numbers and prove some properties for this subset. If the property holds for the superset, I reckon it doesn't automatically hold for the subset too.
Regards,
Theo.
ps: my model works on lists, I just gave an example with natural numbers trying to simplify the technicalities and concentrate on the "structural" question of mine.
- [Coq-Club] embed axiom in a definition, T . Tsokos
- Re: [Coq-Club] embed axiom in a definition, Andrej Bauer
Adam Chlipala
- Re: [Coq-Club] embed axiom in a definition, T . Tsokos
- Re: [Coq-Club] embed axiom in a definition, Adam Chlipala
