coq-club - Re: [Coq-Club] automatic compile with hierarchical module names
chronological Thread
  • To: rabforum <rabforum AT ukr.net>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] automatic compile with hierarchical module names
  • Date: Sun, 17 Aug 2008 11:27:44 -0400
rabforum wrote:
I'm actually trying to run one of Coq's contributions, Constructive Category Theory http://coq.inria.fr/contribs/category.html . I want to use a hierarchical module names, like in this letter about CoLoR: http://pauillac.inria.fr/pipermail/coq-club/2008/003746.html . Unforunatily coq_makefile don't produce Makefile that gives to coqc '-R' option even if I give '-R' option to coq_makefile. So instead of using make I have written a Haskell script that compiles files in a folder and its subfolders in no particular order. Of cause, my script yields errors because of dependencies. So I repeat my script until it yields zero errors.
Is there an easy way, special tools etc.?
There is a manual-ish way that still lets you use coq_makefile to do most of the work. You can run it like:
   coq_makefile A.v COQC="coqc -R B C" COQDEP="coqdep -R B C"
Modify the alternate command line prefixes suggested to include whatever switches you need for your build process, including [-R] path mappings.
