- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] automatic compile with hierarchical module names
- Date: Sun, 24 Aug 2008 05:34:26 +0300
Adam Chlipala wrote:
rabforum wrote:I run this command and its variations.
I'm actually trying to run one of Coq's contributions, Constructive Category Theory http://coq.inria.fr/contribs/category.html . I want to use a hierarchical module names, like in this letter about CoLoR: http://pauillac.inria.fr/pipermail/coq-club/2008/003746.html . Unforunatily coq_makefile don't produce Makefile that gives to coqc '-R' option even if I give '-R' option to coq_makefile. So instead of using make I have written a Haskell script that compiles files in a folder and its subfolders in no particular order. Of cause, my script yields errors because of dependencies. So I repeat my script until it yields zero errors.
Is there an easy way, special tools etc.?
There is a manual-ish way that still lets you use coq_makefile to do most of the work. You can run it like:
coq_makefile A.v COQC="coqc -R B C" COQDEP="coqdep -R B C"
Modify the alternate command line prefixes suggested to include whatever switches you need for your build process, including [-R] path mappings.
$ coq_makefile `cat Make` -I . -R . COQC = "coqc -R . category_theory" COQDEP = "coqdep -c -R . category_theory" -o Makefile
Regretfully it does not work. Sometimes coq_makefile treats variables in command line (COQC = ...) as variables and sometimes as subdirectories. It matters whether spaces are in between "COQC" and "=". And coq_makefile doesn't replace Makefile-s in subdirectories.
After all, this way or another, problem is solved.
- [Coq-Club] automatic compile with hierarchical module names, rabforum
- Re: [Coq-Club] automatic compile with hierarchical module names,
Adam Chlipala
- Re: [Coq-Club] automatic compile with hierarchical module names, rabforum
Adam Chlipala
