- To: "Samuel E. Moelius III" <moelius AT cis.udel.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Questions about eq_rect
- Date: Wed, 27 Aug 2008 18:04:20 -0400
Samuel E. Moelius III wrote:
I've been experimenting with vectors in the style advocated by Adam Chlipala. I'm trying to show that cons commutes with eq_rect, in a certain sense, but I'm having trouble. Here is the lemma.
Lemma lem_cons_eq_rect (f : nat -> nat) (p : forall m, f m = m)
: forall (n : nat) (a : Type),
(forall (x : a) (xs : vector (f n) a),
cons x (eq_rect (f n) (fun m => vector m a) xs n (p n))
= eq_rect (S (f n)) (fun m => vector m a) (cons x xs) (S n)
(f_equal S (p n))).
Here's a quick solution. It's possible to automate this much better, but not without writing a fair amount of Ltac (or using a library that does). And keep in mind that importing Eqdep involves assuming an axiom equivalent to Streicher's K. There's probably a functorized way of getting the same effect in this case without an axiom.
Fixpoint vector (n : nat) (a : Type) {struct n} : Type :=
match n with
| 0 => unit
| S n' => (a * vector n' a)%type
end.
Definition nil (a : Type) := tt.
Definition cons (a : Type) (x : a) (n : nat) (xs : vector n a) := (x, xs).
Implicit Arguments cons [a n].
Require Import Eqdep.
Lemma Lem_cons_eq_rect (f : nat -> nat) (p : forall m, f m = m)
: forall (n : nat) (a : Type) (x : a) (xs : vector (f n) a),
(f_equal S (p n)).
intros until x.
generalize (p n).
rewrite (p n).
intros.
rewrite (UIP_refl _ _ e).
reflexivity.
Qed.
- [Coq-Club] Questions about eq_rect, Samuel E. Moelius III
- Re: [Coq-Club] Questions about eq_rect, Andrew McCreight
- Re: [Coq-Club] Questions about eq_rect, Adam Chlipala
Conor McBride
- Message not available
- Re: [Coq-Club] Questions about eq_rect, Conor McBride
Conor McBride
