- To: "Samuel E. Moelius III" <moelius AT cis.udel.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Questions about eq_rect
- Date: Wed, 27 Aug 2008 19:25:02 -0400
Samuel E. Moelius III wrote:
When you get the error ``Cannot solve a second-order unification problem'', that means that Coq thinks you are asking it to infer a function, correct?
I think that's right.
In the code below, if you comment out the use of ``generalize'', you get this error. So, if the above is right, what is the function that it thinks you are asking it to infer in this case?
Is there a way to find this out, in general?
I think the best way to answer this question is to print the proof terms generated in a number of proofs. You'll see that [rewrite] needs to choose a function that expresses which occurrences of the equality lefthand side you want to replace.
Another little Coq quirk that's good to know for getting more informative error messages in such cases: when you get the second-order unification complaint when trying to rewrite with a proof of [A = B], try running [pattern A] instead. I think it's guaranteed to fail, but the error message expresses why it's not possible to build a well-typed function by abstracting over all occurrences of [A] (which is what [rewrite] does when you don't specify positional arguments).
I don't know if this is the same thing, but I have wondered if there was a theorem in the standard library that would do the following in one step.
apply eq_proofs_unicity.
decide equality.
If anyone knows of such a theorem, I would be interested.
It seems impossible to implement [decide equality] as a theorem without reflecting type syntax into an inductive type.
- [Coq-Club] Questions about eq_rect, Samuel E. Moelius III
- Re: [Coq-Club] Questions about eq_rect, Andrew McCreight
Adam Chlipala
Conor McBride
- Message not available
- Re: [Coq-Club] Questions about eq_rect, Conor McBride
- Re: [Coq-Club] Questions about eq_rect, Adam Chlipala
Conor McBride
