coq-club - Re: [Coq-Club] Axiom of choice
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: Adam Chlipala <adamc AT hcoop.net>, Elnatan Reisner <elnatan AT cs.umd.edu>, Bas Spitters <B.Spitters AT cs.ru.nl>
  • Subject: Re: [Coq-Club] Axiom of choice
  • Date: Thu, 28 Aug 2008 10:52:14 +0100
Hi Andrej,
while everything you say seems correct, I think, I disagree with the gist of it. Per Martin-Loef offered a similar explanation - but then I was never too impressed by authority... :-)
The axiom of choice is typically not valid in any constructive setting
in which:
(a) functions A -> B obey the law of extentionality
   forall f, g : A -> B,
     f = g <-> forall x : A, f x = g x.
(b) and proofs of forall-exists statements need not preserve
equality, i.e., a proof p of
  forall x : A, exists y : B, phi x y
need not satisfy the condition
  forall x y : A, x = y -> p x = p y.
There may be some discussion about what the = sign means.
Indeed.
Type theory satisfies (b) but not (a), and you can prove a
type-theoretic version of choice (just like Elnatan did). A
"mathematical" axiom of choice would be expressed in Coq using setoids,
I don't agree. This "problem" only arises because you are using setoids to represent equality. In my view any construction should preserve equality, which is what we mean by "equal"! Moreover, it would be misleading to imply hat there as an issue with extensionality, Extensionality only exposes the flaw in (b).
I'd like to offer another analysis: the issues with the axiom of choice only arise if we say "A", i.e. accept constructive principles but don't say "B", i.e. use Type Theory to distinguish between Set and Prop.
The type-theoretic version of the existential, the Sigma type, does not live within Prop. I.e. given a set A and a predicate P : A -> Prop, it is not the case that Sigma a:A,P a : Prop. On the other hand, because Sigma a:A,P a Set we can project out the witness.
If we want to stay within Prop, i.e. restrict ourselves to logic, we have to give up this possibility. E.g. this can be achieved by using boxes (in the sense of your paper with Steve Awodey). I.e. we can define
        exists a:A,P a = [Sigma a:A,P a] : Prop
Once, we do this, there is absolutely no reason why we should accept
        f : forall a:A,[Sigma b:A, R a b]
        ac_prop f : [Sigma f : A -> A, forall a:A, R a b]
for an arbitrary A. And indeed Diaconescu's construction shows that we can choose A, s.t. ac_prop implies the excuded middle (in Prop, i.e. [Q \/ not Q]).
It seems to me that the propositional axiom of choice (ac_prop) is the consequence of a certain indeciseveness: once we use the box, we have given up the right to expose the witness - indeed the box is a black one. But then we change our mind and say, actually after all I'd like to use the witness for a construction.
As I have already indicated, there are cases where ac_prop can be justified, e.. if A=Nat. This is a consequence that if A is a trivial setoid then the interpretation of f in the setoid model already contains the choice function we need to prove the conclusions. Since this construction works for any trivial setoid, it applies to any Type which doesn't contain quotients (using extensional or observation Type Theory). Diaconescu's construction on the other hand leads to a setoid A which is highly non-trivial.
Since this is the Coq mailing list, I'd like to remark that I think it is a shame that Coq while originally based on Type Theory is used in a way which strictly separates sets and propositions. This has historic reasons but I think it is time to move on.
Cheers,
Thorsten
P.S. I have copied in Bas, who may have better things to do then to follow the Coq mailing list, since I had a number of related discussions with him.
and it would say that every proof of
gives a function A -> B which respects the equivalence relations on A
and B. This of course cannot be proved, but it is what mathematicians
call axiom of choice (and is the useful version in mathematics, when
setoids or some equivalent are present).
In general, a setting which separates logic and type theory will fail to
prove axiom of choice. This is visible in Coq which distinguishes
This version of choice is provable (because we do everything in Set):
Theorem choice1:
 forall A B : Set,
 forall phi : A -> B -> Set,
 (forall x : A, { y : B & phi x y }) ->
 {f : A -> B  & forall x : A, phi x (f x)}.
But this version is not provable, because we use the existential that
maps into Prop:
Theorem choice2:
 forall A B : Set,
 forall phi : A -> B -> Prop,
 forall x : A, ex (phi x) ->
 ex (fun f : A -> B => forall x : A, phi x (f x)).
I hope I got the examples right.
Best regards,
Andrej
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
