coq-club - Re: [Coq-Club] Axiom of choice
chronological Thread
  • To: Elnatan Reisner <elnatan AT cs.umd.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Axiom of choice
  • Date: Wed, 27 Aug 2008 19:44:39 -0400
Elnatan Reisner wrote:
Can someone shed some light on this contradiction? Are some forms of the
axiom of choice provable and others not?
In constructive logic, certain statements of the axiom of choice are trivial, since proofs of existence give effective methods for computing the things that exist.
One big source of confusion here is the [Prop]/[Set] distinction in Coq, which has no counterpart in almost any other formal system, least of all set theory, where proofs are considered to exist in some separate magical universe. To (A) make extraction effective and (B) avoid surprising consequences of impredicativity, Coq imposes serious elimination restrictions on [Prop], which enforce lack of "information flow" from proofs to programs. One statement of AC in Coq is essentially a controlled way of casting from existential packages in [Prop] to their counterparts in [Set]. Such an axiom is interesting for a completely different reason than AC is interesting in ZF; the "philosophical commitments" that the two axioms propose are completely disjoint, as far as I understand.
You can find a slew of variants of AC in the Logic.ChoiceFacts module. Further dimensions of variation that are interesting in Coq include converting relations to functions and statements about how there exist unique elements satisfying relations.
I'm sort of imagining that Coq's [Type] is analogous to the verboten
set-of-all-sets (hoping that the type hierarchy makes this okay)
Well, the type hierarchy makes the analogy wrong, IMO. ;)
and I
imagine reading [x : A] as 'x is an element of A'. Does it make sense to
think of things this way?
Yes and no. It can be a reasonable source of intuitions, but you just won't find any way to reify type membership as a proposition in the way you are probably hoping to.
And if so, is there a way better to say that
something is in a particular type? Below, I write
{x : F a | True}
to mean that [F a] is nonempty, and
exists x : F a, f a = x
to mean that [f a] is in [F a].
Neither of these conventions accomplishes anything logically. Terms have types intrinsically in Coq; you don't need to state propositions to impose such constraints. Sometimes you want to "inject" a non-[Prop] term into [Prop] with a type family like the standard library's [inhabited], but this has no deep interpretation in the standard, set-theoretical view of the world.
I think what you are discovering, with your difficulties crafting a satisfying statement of AC, is that the elements of AC-stated-for-ZF that you think of as critical are actually barely worth saying in constructive logic. You need one or more of the "gimmicks" of the later versions of AC from Logic.ChoiceFacts for things to get interesting in that kind of way.
