coq-club - [Coq-Club] Coq 8.2: Sort polymorphism and the module system
chronological Thread
  • To: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Coq 8.2: Sort polymorphism and the module system
  • Date: Fri, 29 Aug 2008 11:54:01 -0400
Hi,
I have a question about Coq 8.2 (beta), specifically about sort polymorphism and the module system. I'm going to use the FSets library as an example.
Require Import FSets.
Module NatSet := FSetWeakList.Make Nat_as_DT.
Print NatSet.elt.  (* NatSet.elt = nat : Type *)
My question: Given the definition of NatSet.elt, I would expect that it could be given type Set. After all, nat has type Set. However, "Check (NatSet.elt : Set)" fails. Why is this the case? Judging from the description of sort polymorphism in the reference manual, perhaps I'm expecting more than is actually the case?
Thank you for help and pointers,
Brian
