coq-club - Re: [Coq-Club] newbie question
chronological Thread
  • To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] newbie question
  • Date: Fri, 29 Aug 2008 14:22:11 +0200
Hello,
I believe the following is an example where psatz fail, but Frédéric Besson
may know ways to parameterize the tactic that make it succeed.
Lemma ex2 : forall x, 0 < (3 * x - 4) * (3 * x - 5).
intros; psatz Z.  (* here the program seems to compute for ever. *)
Indeed, it will!
As you explain below, psatz is only reasoning over R:
If the goal is provable over Z but not over R, the tactic is very very likely to fail
(the only bit of Z reasoning is the removal of strict comparisons: x > y --> x -1 >= y)
Now we can prove ex2, because the formula is a product of two monomials that
are either both positive (when 2 <= x) or both negative (when x < 2). Here is
a proof.
intros x.
case (Z_le_dec 2 x); intros x2.
apply Zmult_lt_0_compat; omega.
replace ((3*x-4)*(3*x-5)) with ((4-3*x)*(5-3*x)) by ring.
Qed.
Here, you could still get a bit more of automation using psatz.
intros x.
case (Z_le_dec 2 x) ; psatz Z.
Qed.
psatz works by extracting from the goal a polynomial that is always positive on
the real line. Here the most natural polynomial is (3*x-4)*(3*x-5) but although
this polynomial is positive on all integers, there are real numbers for which it
is negative (3/2, for instance), I relied on this and hoped that it would provide
an example of a provable goal that cannot be proved using psatz. It worked!
Nevertheless, I was suprised by the behavior of the tactic on the following two examples:
forall x, (x+10)*(3*x-4) <= 0 -> x < 2  (success)
forall x, (x + 10) * (3 * x - 4) * (3 * x - 5) * (3 * x - 7) <= 0 - > x < 3 (failure, but this goal is
provable, using the same technique as above)
Frédéric may be able to add some information and documentation.
Humm, I do not really know what is going on -- it is fairly difficult the understand the limits of csdp.
BTW, the csdp driver is taken from J. Harrison Hol Light sos module -- it can prove amazing things!
What is for sure is that:
- the tactic normalises  polynomials.
    Your goal is boils down to this nasty one
forall x, 27 * x ^ 4 + 126 * x ^ 3 - 1191 * x ^ 2 + 2350 * x - 1400 <= 0 -> x < 3.
- the degree of polynomials has a strong impact on csdp
- csdp is using numeric methods and might therefore miss a proof.
I tried to solve your goal by hand and it appears that psatz fails on embarrassingly simpler sub-goals.
I will investigate that...
BTW, if Coq users stumble on non linear polynomial goals that cannot be solved automatically, I am client -- drop me a mail !
Frédéric
