- To: coq-club AT pauillac.inria.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Enhancing Records
- Date: Thu, 11 Sep 2008 10:56:01 +0200 (CEST)
- Importance: Normal
I had some problem with Extraction function,
Records are known to be non-recursive in Coq,
but in CaML, we can use recursive records such as:
type foo = Foo | Foobar of bar
and bar = {x : foo; y : bool}
this type is "inductively" correct, as "proven" in the Coq term:
Require Import Bool.
Inductive foo : Set :=
| Foo : foo
| Foobar : bar -> a
with bar : Set :=
| Build_bidule : foo -> bool -> bar
but the extracted type is not a Record (hopefully, since
we didn't provided the field names), and I want it to be
a Record, so a mechanism such as:
| Foo : foo
| Foobar : bar -> a
with bar : Set :=
as Record [ x y ]
would be usefull to change easily the status of an Inductive type
(maybe not as readable as
| Foo : foo
| Foobar : bar -> a
with bar : Set :=
| Build_bidule : {x : foo; y : bool} as Record
or so...)
I do not really know what problems can be encountered;
I believe this is just a flag to set in Coq to be extracted
as record type.
For other languages, such as Haskell, as I don't know them,
I don't know if it is problematic.
Am I wrong and have to do without those Record or could it
be implemented and added to Coq features?
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] Enhancing Records, AUGER Cédric
- Re: [Coq-Club] Enhancing Records, Hugo Herbelin
